H323 calls are not supported when registered to CUCM. You either need to register as SIP and H323 to VCS, or use VCS to interwork from SIP to H323.
All that said, even when using VCS for interworking, there's no native IP dialling from CUCM, although you can "fake it" with SIP route patterns such as 'ip@[ipaddress]' then send the call to VCS which can strip the 'ip@' portion.
I know this probably isn't what you were looking to hear, but CUCM based integrations are very much SIP centric with H323 interoperability being less capable than VCS or stand alone deployments.
