How register EX90 tc4.2.3 whit CUCM 7.1.5?
PEREZ DAVID
I try configure the EX90 with third-party SIP Device (Advance) but no yet register.
also configure in EX90
provisioning --> ExternalManager --> address: IP Publisher
SIP -- > Profile 1 -- > Extension@IP Publisher
DefaultTrasport: Auto
Type: Cisco
Proxy 1:  Manual  ---> IP Publisher
Authentication 1 --> LoginName: UserDigest  Passwrod: Digest Credentials
CUCM
Device Name: MAC EX90
DP, Location, CSS, Device Security Profile, SIP Profile, Digest User.
Line 1 Extension
Try with SIP Basic also but no register.
Amlesh Sengar
  The units can be registered to cucm as third party (basic) endpoints.
Please find the steps to register.
Configure sip settings on unit such as sip uri and proxy address.
1.  Sip Mode: on
2.  SIP Uri:    DN@ipaddress of cucm   eg: 9011@10.10.10.1
3.  Discovery : manual
4.  proxy Address:  ip address of cucm.
5.  Type: standard
6.  Default Transport: let it be auto however incase that did not work, change to udp.
7.  TLs: off
8:  Sip authentication user name:  user you have created on cucm  eg  9011
9.  Password:  use same password configured while creating user  9011
10. Disable provisioning mode.
CUCM config:
1.  Select third party basic profile.
2.  add mac address of mxp endpoint.
3.  select proper sip profile, phone templates etc.
4.  under digest user and owner user id select the same user eg: 9011
5.  save the configuration and assign same DN that we used in sip uri settings on mxp.
6.  Also associate mxp device to user using device association pane on cucm.
Please let me know if these work for you. I have tried this in my lab and that works.
Amlesh
5 Replies 5
Amlesh Sengar
1.  Sip Mode: on
5.  Type: standard
7.  TLs: off
CUCM config:
Amlesh
Amlesh Sengar Hi Thanks for you respond. Is right. The EX90 was registered with CUCM  also using third party Third-party SIP Device. Best regards.
Please confirm if the EX90 is not registered to call manager with the configuration provided above.
Incase it does not registered.  please provide xstatus sip from API mode.
Also type command " log ctx sippacket debug 9", this will enable sip packets sent/received to EX90.
check the response received from CUCM.
Note: disable debug using command " log ctx sippacket debug off"
Amlesh
gogasca
Level 10
Level 10
as a recommendation you should be running TC5 and CUCM 8.6 to get a native functionality for TAA endpoints.
Hi Thanks for recommender You know  EX 90 support multi conference in the version TC 5 with CUCM 8.6. Best regards
