How to change FXO volume ?
Omid Almasieh
Hi everyone,
I've configured two FXO ports attached to two routers in different cities,I have some ip phones registered in CME too,the problem is that when with iphones dial some analog phones that connected through FXO to PBX the sound volume is very low,how can I change sound volume on VIC2-4FXO ports?
Aaron Harrison
Use these commands under the voice-port:
Input gain < --- this one will take a positive number to make sound louder in the input direction
Output attenuation < --- this one will take a negative number to make sound louder in the output direction
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Awesome,thnaks for your reply
