01-06-2016 02:36 PM - edited 03-18-2019 05:23 AM
We recently had a Cisco TelePresence Profile 65 system donated. We did not get any documentation and I have been unable to locate instructions for the lcd screen. The screen has several inputs and RS232. I would like to figure out how to change the screen input. Could someone explain how this would be done? I assume its over rs232 because I cant find any buttons on the unit. Is there an API for the screen? What are the communication settings for the screen?
Any help is most appreciated.
Thank you
James
Solved! Go to Solution.
01-06-2016 08:19 PM
The screen is designed to work with the endpoint, I'm not sure how much luck you'll have with operating it independently. I've not seen the commands to control the screen documented anywhere.
You'll find the Admin and install guides on the Cisco website which may help you get the system operational and then be able to use it to change to another input source.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
01-06-2016 08:19 PM
Wayne
01-07-2016 01:10 PM
Thank you very much for providing those links and the information. This is our first experience with the Profile series equipment. Its good to know that it wasn't designed to operate independently.
