06-16-2013 06:46 AM - edited 03-18-2019 01:17 AM
One of our clients using Cisco MSE8000 MCU with 30 port 8420 media card
for vedio Conferencing for different remote Intranet locations. How can i check
Vedio Latency at remote Locations where Camera has connected ?
Plz explain with Commands and simple exact procedure.....
KS
06-16-2013 04:41 PM
An ICMP ping is the easiest to see the latency to the MCU itself.
Regards RTP, check the RTCP values, for example with a network analyzer / wireshark.
If you see your self view via the mcu you could also measure the time of a local recording where you
show something till you see it on the screen :-)
06-18-2013 07:45 AM
Hi Martin,
How can i measure at the time of recording on screen....can you please share Snapshot for this
KS
