How to Check Vedio Latency
Kuldeep singh
One of our clients using Cisco MSE8000 MCU with 30 port 8420 media card
for vedio Conferencing for different remote Intranet locations. How can i check
Vedio Latency at remote Locations where Camera has connected ?
Plz explain with Commands and simple exact procedure.....
KS
Martin Koch
An ICMP ping is the easiest to see the latency to the MCU itself.
Regards RTP, check the RTCP values, for example with a network analyzer / wireshark.
If you see your self view via the mcu you could also measure the time of a local recording where you
show something till you see it on the screen :-)
Hi Martin,
How can i measure at  the time of recording on screen....can you please share Snapshot for this
KS
