How to connected New Cisco Ceiling Microphone Pro with Room Kit pro
batistarodris
One of customer  wants to use 2 units of the Cisco Ceiling Microphone Pro (CS-MIC-CLGPRO=) with the Cisco Room Kit Pro Bundle (CS-KITPRO-K9) Could you please confirm how the microphones should be connected to the CODEC?
Thanks for help.
Matt_W
Level 3
Level 3
The Cisco Mic Pros connect through a Ethernet connection.  If you are limited on those connections due to peripherals connecting to the codec then you would want to connect a locally managed switch to the codec and then connect the mics to the switch.
You should use Audio over IP. Connect the MICS Pro to a PoE port on the Room Kit Pro. If you have multiple devices, ensure you have a PoE switch between the codecs and MICs.
Response Signature
