How to Delete TMSPE (SQL database tmspe) - TMS
I just try to uninstall TMSPE and after that try to reinstall TMSPE, but it say "Database 'tmspe' cannot be opnened. It has been marked SUSPECT by recovery."
How can I reinstall TMSPE if the database tmspe marked SUSPECT?
TMS version      : 14.3.0
TMSPE version  : 1.1
Below screeen capture,
Please advise.
Ovindo
I'm using 2008 R2:
but you can download SQL Server Management Studio Express from Microsoft, it's free
http://www.microsoft.com/en-au/download/details.aspx?id=7593
Mind you, if you're a bit uncomfortable making these kind of changes, then I would seriously consider opening a case with TAC.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
6 Replies 6
Jens Didriksen
Level 9
Level 9
I would've thought it would've asked if you wanted to use the existing db or create a new one. but maybe not.
RDP to the server where tmpse db is installed, open SQL Server Management Studio, then expand the database folder in the left pane, select tmpse database and delete it.
Re-install TMSPE and rebuild the database all over again.
/jens
Hi Jens,
Thanks for fast response,
Where I can Find SQL Management Studio, it's included in SQL Server 2008? or excluded?
Ovindo
Btw I use SQL Server 2008
I'm using 2008 R2:
/jens
Dear Jens,
Thanks a lot
Ovindo.
It worked ok?
/jens
