08-07-2012 07:55 AM - edited 03-17-2019 11:34 PM
While we are dialing Point to Point, DuoVideo Options gives us the Flexibility of toggling between Far End Video and Far End Presentation(Content). However same is not available in case when we dial through Codian MSE 8510 MCU.
Does it means that during multisite dialing, Duo Video Option is not available even though H.239 Protocol is enabled at MCU ?
08-30-2012 05:25 AM
HI C_kapil. Yes. Seems the MCU can't send content to the those endpoints cause the codec doesn't match, or the codec you have selected is not compatible with those endpoints.
Navigate to Settings>Content on the MCU if you can. Outgoing codec, what is that set for? Looks like you have it set to H264. If the those endpoints don't support duo video on H264, MCU can't send it content if the outgoing content codec is something it doesn't support. Try changing to H263 or Auto on the Settings>Content page for the outgoing codec. If you do, retest and let us know.
Thanks in advance.
VR
Patrick
08-31-2012 05:31 AM
08-31-2012 05:34 AM
Dear Patrik,
Outgoing Codec has been set at 263+ now. Snapshot is enclosed for reference. At MCU Dual Steams are received but not at Far End Endpoint.
VR
Kapil
08-31-2012 05:44 AM
HI C-Kapil. It looks like the MCU is doing its job in sending it to the far end. Can you test between two MXPs to verify? I'd also check the stats on PCS-1 to see if its receiving a dual stream or not, but by the looks of things from your snapshot, the MCU is sending it now with the site being the source of the content. I'd have to check the endpoint side, or PCS-1 to see if its receiving content or not. The stats may show its receiving it, but can't display it perhaps?
What is PCS-1 in this call?
VR
Patrick
09-04-2012 08:33 PM
Dear Patrick
It worked after disabling Dual Monitor options. Thanks a Lot.
VR
Kapil Choudhary
Mgr(Systems)
SBI
Hyderabad.
09-05-2012 05:08 AM
HI Kapil. Thanks for the heads up. Glad all is working now!
VR
Patrick
