how to get the serial for CTS-T3
Yazen Alaa
Dear All
I am trying to get the serial number for T3 becasue theTCU for T3 is faulty and it needs to replace .
my Question : how to get the serial number for T3 , and where is located to ?  . from the web i didnt find it
where can i find it in chase ?
thanks
Yazen Alaa
any expert can help ?
thanks
Martin Koch
Do you have the system in TMS, there you might see it.
Besides that, the T3 should consist of multiple C90 codecs,
on the unit as well as on their CLI / webinterface you should be able to find their
serial numbers, which might lead to the main number.
You can also try to look through the documentation:
http://www.cisco.com/c/en/us/support/collaboration-endpoints/telepresence-system-t3/model.html
It should also be somewhere mentioned in the order confirmation of the t3 or of the service contract.
Besides that, simply write a mail to tac@cisco.com and ask how to identify the main serial number of the unit.
Please let us know how you solved it.
