How to reenable SpeakerTrack when disabled from Touch10
jbburks
Level 5
Level 5
I have an MX700D with SpeakerTrack. It is at a remote location.
Apparently the end user used the controls on the Touch 10 to disable SpeakerTrack - it's not zooming in.
Is there a way in the web GUI or command line to check and reenable this?
Patrick Sparkman
There isn't any type of configuration option within the web interface to activate SpeakerTrack, however you can with the API through the web interface under Configuration > API, or using SSH.
xCommand Cameras SpeakerTrack Activate
SpeakerTrack status can be checked under Configuration > System Status > Cameras > Speakertrack, or using SSH:
xStatus Cameras SpeakerTrack Status
