How to register Telepresence Profile 55 into CUCM8.6
iantra123
Level 3
Level 3
We try to registre a TPS 55 C40 with a CUCM using SIP but it can't.
Does anyone have succeed with it?
also how to add the Directory Server? How to configure so it can see the LDAP directory or can see the directory of the CUCM ?
Is there any link for help?
antra
15 Replies 15
iantra123
Level 3
Level 3
For the registration, I've followed the document on administering TC Endpoint with CUCM8.6.
but the actual problem is that the registration is rejected
So what can I do so that it will be registered.
regards
Antra
HI Antra - Have you loaded the cop.sgn file for the TC5.1.4 to the CUCM? Can you verify this?
Also, I'm assuming that your profile has touch panel?  If you run the provisioning wizard from the touch panel, does it do the same?
VR
Patrick
The result i've shown previously is a result from auto-Registration from the TPS.
i.e i've used the provisioning wizard from the touch pannel.
also i see in the touch pannel:
SIP URI=AUTO-REGISTER@IP_address_of_the_subscriber_CUCM.
Proxy=IP_address_of_the_subscriber_CUCM.
login :
password :
Thanks.  Is the cop.sgn file loaded as well?
VR
Patrick
Why do I need the cop file if the datasheet says :
• Native registration with Cisco Unified Communications Manager (CUCM)
• Basic CUCM provisioning
• Firmware upgrade from CUCM
does it not already bundled with CUCM?
Antra
Patrick Pettit
I dont believe that cop.sgn file is bundled.  Before I ask for any tracing to be done, I'd like for you to confirm its loaded in OS Administration if you can.  I want to rule this out before proceeding.
VR
Patrick
OK,
Let me download the cop file from cisco and come back after.
Antra
To troubleshoot you can connect to the codec/profile as admin and do :
log ctx prov debug 9
log ctx sipreg debug 9
log output on
And you should see any sip registration attempts and provisioning debug.
Also, from admin shell you can do :
xstatus sip
xstatus provisioning
xstatus Provisioning
*s Provisioning Status: Provisioned
*s Provisioning Reason: ""
*s Provisioning Software UpgradeStatus SessionId: ""
*s Provisioning Software UpgradeStatus LastChange: "2012-09-20T06:40:04Z"
*s Provisioning Software UpgradeStatus Status: None
*s Provisioning Software UpgradeStatus Phase: None
*s Provisioning Software UpgradeStatus Message: ""
*s Provisioning Software UpgradeStatus VersionId: ""
*s Provisioning Software UpgradeStatus URL: ""
*s Provisioning Software Current VersionId: ""
*s Provisioning Software Current URL: ""
*s Provisioning Software Current CompletedAt: ""
*s Provisioning CUCM CAPF Mode: IgnoreAuth
*s Provisioning CUCM CAPF ServerName: "10.48.55.161"
*s Provisioning CUCM CAPF ServerPort: 3804
*s Provisioning CUCM CAPF LSC: Installed
*s Provisioning CUCM CAPF OperationState: NonPending
*s Provisioning CUCM CAPF OperationResult: CAPFLSCUpdated
*s Provisioning CUCM ProvisionSecurity: Signed
*s Provisioning CUCM CTL State: Installed
** end
OK
COP file tells CUCM the capabilities of the endpoints/profile.
Thank you already for your answers.
I've checked in Cisco download and saw the file s52000tc5_1_4.pkg but i don't see the cop.sgn.
I've tried to unrar or uncopress it with 7Zip it but no success.  any idea?
Second : This is the result of the auto-provisionning
xstatus SIP
*s SIP Proxy 1 Status: Active
*s SIP Proxy 1 Address: "10.10.40.2"
*s SIP Proxy 1 Secure: False
*s SIP Proxy 1 Verified: False
*s SIP Registration 1 Status: Failed
*s SIP Registration 1 Reason: "403 Forbidden"
*s SIP Registration 1 URI: "6019@10.10.40.2"
*s SIP Registration 1 Authentication: Off
*s SIP Profile 1 Proxy 1 Status: Active
*s SIP Profile 1 Proxy 1 Address: "10.10.40.2"
*s SIP Profile 1 Secure: False
*s SIP Profile 1 Verified: False
*s SIP Profile 1 Authentication: Off
*s SIP Profile 1 Registration 1 Status: Failed
*s SIP Profile 1 Registration 1 Reason: "403 Forbidden"
*s SIP Profile 1 Registration 1 URI: "6019@10.10.40.2"
** end
OK
*s Provisioning Status: Idle
*s Provisioning Software UpgradeStatus LastChange: ""
** end
OK
Shoud I configure the user credential for this telepresence?
regards
Antra
I've added the User Credential, then the CTS can register in the CUCM. fine.
But now : they can't make a call.
The CTS can see directory :OK,
But  if I try to make a call then the call is disconnected directly
Any idea?
Antra
Hi.
You do not need any COP installed to use TC software on the CUCM.
If you cant make calls, please make sure that the TC software on the endpoint is the newest one.
TC4.x and below are not supported by CUCM.
For troubleshooting:
1. Check software versions. Should be at 5.x
2. Check DNS settings on profile, to make sure the CUCM domain address is resolveable by the endpoint.
3. Check if you can see the IP for the system in CUCM. ( If there is no ip then endpoint is NOT SIP-registred to the CUCM - investigate that )
4. Make sure that the profile reports of no errors  ( look at sip registration )
//Marius
Hi Antra
That sounds like codec mismatch issue.
I would check your region settings and look in the logs for disconnection issue.
Cheers
Rafal
Patrick Pettit
Since it seems you have a DN now, I would check your Calling Search Space. When the call is placed maybe the ccm cant find the number your looking for since it may be in a different CSS. Also, if your calling over to VCS, I would check search history there to see if it was found or not.
VR
Patrick
Sent from Cisco Technical Support Android App
Hi all,
Firmware is TC5.1.3.292001
The CTS can be called, but can't make a call.
If I make a call from a 9971, voice gateway to the CTS, then the call pass.
but If I make a call from the CTS then the call cannot pass.
They (IPPhone, CTS, VoiceGateways) are in the same CSS, Location, Device-pool,Region,  MRGL, MoH, ...
I've checked also in the SIP Profile, that cisco recomends, then see these parameters :
    - redirect by application = yes
    - use FQDN in SIP request = yes ==> I don't know if this is suitable for calls but cisco have given it in their site.
    - Allow presentation sharing BFCP = yes
But still no success.
Below is a result of the debug from one CTS that try to make call to 6008
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.09.24 16:44:30 =~=~=~=~=~=~=~=~=~=~=~=
1052.24 SipReg   Scheduling new keep-alive for proxy 10.10.40.2 in 30 seconds.
1052.27 SipReg    Starting work timer (outboundindex: 0).
1052.57 SipReg    Executing SIPREG_Active_doSIPRegWorkTimeout.
1052.57 SipReg    Stopping work timer because we have nothing more to do.
1062.27 SipReg    Starting work timer (outboundindex: 0).
1062.57 SipReg    Executing SIPREG_Active_doSIPRegWorkTimeout.
1062.57 SipReg    Stopping work timer because we have nothing more to do.
!!! make a call
Command not recognized.
!!! make a call
!!! make a call
!!! make a call
!!! make a call to 1072.27 SipReg    Starting work timer (outboundindex: 0).
61072.57 SipReg    Executing SIPREG_Active_doSIPRegWorkTimeout.
1072.57 SipReg    Calling SIPREG_doRegister to refresh registration.
1072.57 SipReg    Setting status for regno 0 to 1, refresh=0 (cause: )
1072.57 SipReg   Not informing SipDialog about re-registration
1072.57 SipReg   Sending register request for sip:6019@10.10.40.2 to 10.10.40.2.
1072.57 SipReg    Starting work timer (outboundindex: 0).
1072.58 SipReg    Setting status for regno 0 to 2, refresh=90 (cause: )
1072.58 SipReg    Sending registration status to stack and SipUa.
1072.58 SipReg    Sending server status information upwards.
01072.87 SipReg    Executing SIPREG_Active_doSIPRegWorkTimeout.
1072.87 SipReg    Stopping work timer because we have nothing more to do.
08
!!! make a call to 6008
1082.24 SipReg   Scheduling new keep-alive for proxy 10.10.40.2 in 30 seconds.
1082.27 SipReg    Starting work timer (outboundindex: 0).
1082.57 SipReg    Executing SIPREG_Active_doSIPRegWorkTimeout.
1082.57 SipReg    Stopping work timer because we have nothing more to do.
1086.53 IXUser I: iXController(0x12d13380) registerProtocolUser: proto=1, user=0x12d60f58
1086.53 IXUser I: iXController(0x12d13380) registerProtocolUser: proto=2, user=0x12d31750
1086.56 MC I: Conference::addRemoteParticipant(p=5,ch=3) adding modecontrol shared channel
1086.56 MC I: Conference::modeChanged(c=4) holder=-1  Video (3): vid-off 0x0@0.0  0k
1086.56 MC I: RemoteParticipant::outgoingDuoModeChanged(p=5, ch=3): ModesController wants to run mode: Video (3): vid-off 0x0@0.0  0k
1086.57 CAMERA I: CamVisca::Ready_doCAMActionReq cameraId=1 actionId=1
1086.57 RTP I: SockPair::dynamic(sock=0) retrying next pair (rtp port=16414)
1086.57 RTP I: SockPair::dynamic(sock=1) retrying next pair (rtp port=16416)
1086.57 RTP I: SockPair::dynamic(sock=2) retrying next pair (rtp port=16418)
1086.57 RTP I: SockPair::dynamic(sock=3) retrying next pair (rtp port=16420)
1086.58 RTP I: SockPair::dynamic(sock=4) retrying next pair (rtp port=16422)
1086.58 CAMERA I: CamVisca::Ready_doCAMActionReq cameraId=1 actionId=19
1086.58 DATACTRL I: DataGateAddReq(ig=4) assoc gate -1 hdlc=yes
1086.66 MC I: MediaServerAction(): InputGate(ig=63) creation took 104 miliseconds
1086.66 MC I: MediaServerAction(): InputGate(ig=71) creation took 104 miliseconds
1086.68 CAMERA I: CamVisca::sendCAMPositionInd cameraId=1 pos=400/60/0/4577
1086.80 RTP I: TrafficCtrl: Added new entry (main): id: 32, tcid: 65568
1086.81 MC I: MediaServerAction(): InputGate(ig=66) creation took 251 miliseconds
1086.81 RTP I: TrafficCtrl: Added new entry (duo): id: 34, tcid: 65568
1086.83 MC I: MediaServerAction(): InputGate(ig=69) creation took 267 miliseconds
1086.83 MediaStreamController I: MV::getVCSetting getOutputPortStatus initialized 1
1086.83 MediaStreamController I: MV::getVCSetting localHwCookieHint_ 0 w 1280 h 720
1086.84 MediaStreamController I: MV::getVCSetting getOutputPortStatus initialized 1
1086.84 MediaStreamController I: MV::getVCSetting localHwCookieHint_ 8 w 1920 h 1080
1086.84 RTP I: TrafficCtrl: Added new entry (duo): id: 38, tcid: 65569
1086.87 MC I: CallParticipantImpl: calledUri: sip:6008@10.10.40.2
1086.87 SipCall I: ==== makeOutgoingCall appId=5, stackId=na
1086.88 MC I: RemoteParticipant::proposeMode(p=5, ch=1): Did not find mixer ((nil)) or channel (0x12d3185c)
1086.88 MC I: RemoteParticipant::propose60fpsThreshold(p=5, ch=1): Did not find mixer ((nil)) or channel (0x12d3185c)
1086.88 MC I: RemoteParticipant::reevalRefMode(p=5,ch=1) set ref [Audio (1): G.711a  64k ] q= auto, t60=6000
1086.89 MC I: RemoteParticipant::reevalRefMode(p=5,ch=2) set ref [Video (2): vid-off 0x0@0.0  0k ] q= auto, t60=6000
1086.89 MC I: RemoteParticipant::reevalRefMode(p=5,ch=3) set ref [Video (3): vid-off 0x0@0.0  0k ] q= auto, t60=6000
1086.89 MC I: RemoteParticipant::proposeMode(p=5, ch=4): Did not find mixer ((nil)) or channel (0x12d376ac)
1086.89 MC I: RemoteParticipant::propose60fpsThreshold(p=5, ch=4): Did not find mixer ((nil)) or channel (0x12d376ac)
1086.89 MC I: RemoteParticipant::reevalRefMode(p=5,ch=4) set ref [Data (4): H.224-HDLC  64k ] q= auto, t60=6000
1086.89 MC I: RemoteParticipant::reevalRefMode(p=5,ch=5) set ref [Video (5): vid-off 0x0@0.0  0k ] q= auto, t60=6000
1086.89 MC I: MediaServerAction(): InputGate(ig=73) creation took 330 miliseconds
1086.89 SipCall I: sip_call_handler::handleSIPMRtpLocalCapsetInd(5/-1/-1, capsetentries: 27): Received local capset with payload types set
1086.89 MC I: RemoteParticipant::configureIncomingChannel: Capability table:
1: (2) H.264 maxbr=6000000 maxfs=9000 maxmbps=245000 maxsmbps=245000 maxfps=6000  [97]
2: (2) H.264NIL maxbr=6000000 maxfs=9000 maxmbps=245000 maxsmbps=245000 maxfps=6000  [98]
3: (2) H.263PP maxbr=2000000 fps-qcif=3000 fps-cif=3000 fps-4cif=3000 fps-sif=3000 fps-4sif=3000 fps-vga=3000 fps-svga=3000 fps-xga=3000 fps-wcif=3000 fps-w4cif=1500 fps-w720=1000 fps-wxga=1000  [99]
4: (2) H.263 maxbr=2000000 fps-qcif=3000 fps-cif=3000 fps-4cif=3000  [34]
5: (2) H.261 maxbr=2000000 fps-qcif=3000 fps-cif=3000  [31]
6: (3) H.264 maxbr=6000000 maxfs=3840 maxmbps=108000 maxsmbps=108000 maxfps=6000 feat=Pres-Token  [97]
7: (3) H.264NIL maxbr=6000000 maxfs=3840 maxmbps=108000 maxsmbps=108000 maxfps=6000 feat=Pres-Token  [98]
8: (3) H.263PP maxbr=2000000 fps-qcif=3000 fps-cif=3000 fps-4cif=3000 fps-sif=3000 fps-4sif=3000 fps-vga=3000 fps-svga=3000 fps-xga=3000 fps-wcif=3000 fps-w4cif=1500 fps-w720=1000 fps-wxga=1000 feat=Pres-Token  [99]
9: (3) H.263 maxbr=2000000 fps-qcif=3000 fps-cif=3000 fps-4cif=3000 feat=Pres-Token  [34]
10: (3) H.261 maxbr=2000000 fps-qcif=3000 fps-cif=3000 feat=Pres-Token  [31]
11: (1) AAC-LD rate=128k profile=25  [100]
12: (1) AAC-LD rate=64k profile=24  [102]
13: (1) AAC-LD rate=56k profile=24  [103]
14: (1) AAC-LD rate=48k profile=24  [104]
15: (1) G.722.1 rate=32k ptime(ms)=40  [105]
16: (1) G.722.1 rate=24k ptime(ms)=40  [106]
17: (1) G.722 rate=64k ptime(ms)=40  [9]
18: (1) G.711a rate=64k ptime(ms)=40  [8]
19: (1) G.711mu rate=64k ptime(ms)=40  [0]
20: (1) RTP-Dtmf  [101]
21: (2) RTCP-Feedback-PLI
21: (2) RTCP-Feedback-FIR
21: (3) RTCP-Feedback-PLI
21: (3) RTCP-Feedback-FIR
22: (3) H.239Ctrl
23: (4) H.224-HDLC  [107]
23: (4) H.224  [107]
Simcapset:
(1) {11,12,13,14,15,16,17,18,19,20}{1,2,3,4,5}{6,7,8,9,10}{23,23}
1086.91 VIDEOCTRL-0 I: (proxy,161) maximum number of framestorage slices 2
1086.91 DATACTRL I: DataGateCfgReq(ig=4) hdlc=yes
1086.94 MC I: VideoInputGateImpl::inputGateConfigState(ig=66): DecoderConfig[66]: maxMbps: 244980 maxWidth: 1920 maxHeight: 1200 memsize: 74432424
1086.95 SipStack I: SipDialog(ui=5,s=0) sendInviteRejToStack (403:Forbidden)
1086.95 MC W: Mcfsm::handleOtherMessages() unknown msg SIP_DialogFreed_Ind from SipStack
1086.95 SipCall I: sip_call_handler::handleSIPMCallRej(5/0/-1): Call rejected (cause: Forbidden)
1086.96 MC I: signalLocalReceiveCapsetChange, RemoteParticipant::signalLRCap
1086.96 SipCall I: ==== makeOutgoingUpdate appId=5, stackId=-1, eventCookie=-1, isEmptyCap=0, holdState=0
1086.96 MC I: RemoteParticipant::setRRRate(p=5): Received new remote rate from protocol: 0 (old: -1)
1086.96 MC I: RemoteParticipant::modeChanged(p=5, ch=1): ModesController wants to run mode: Audio (1): aud-off  0k
1086.96 SipCall I: ==== signalOutgoingModeChange appId=5, stackId=-1, eventCookie=-1, isEmptyCap=0, holdState=0
1086.97 MC I: configureOutgoingChannel(p=5, ch=1): Configuring mode : Audio (1): aud-off  0k  (modescontroller says real is: Audio (1): aud-off  0k )
1086.97 MC I: RemoteParticipant::modeChanged(p=5, ch=2): ModesController wants to run mode: Video (2): vid-off 0x0@0.0  0k
1086.97 SipCall I: ==== signalOutgoingModeChange appId=5, stackId=-1, eventCookie=-1, isEmptyCap=0, holdState=0
1086.97 MC I: configureOutgoingChannel(p=5, ch=2): Configuring mode : Video (2): vid-off 0x0@0.0  0k  (modescontroller says real is: Video (2): vid-off 0x0@0.0  0k )
1086.97 MC I: Delaying setting of media mode Video (2): vid-off 0x0@0.0  0k  because the RTP addresses are missing.
1086.97 MC I: RemoteParticipant::modeChanged(p=5, ch=3): ModesController wants to run mode: Video (3): vid-off 0x0@0.0  0k
1086.97 MC I: Conference::calcCommonRate(c=4,ch=3) rate=0
1086.98 MC I: RemoteParticipant::modeChanged(p=5, ch=4): ModesController wants to run mode: Data (4): data-off  0k
1086.98 SipCall I: ==== signalOutgoingModeChange appId=5, stackId=-1, eventCookie=-1, isEmptyCap=0, holdState=0
1086.98 MC I: configureOutgoingChannel(p=5, ch=4): Configuring mode : Data (4): data-off  0k  (modescontroller says real is: Data (4): data-off  0k )
1086.98 MC I: RemoteParticipant::modeChanged(p=5, ch=5): ModesController wants to run mode: Video (5): vid-off 0x0@0.0  0k
1086.98 MC I: configureOutgoingChannel(p=5, ch=5): Configuring mode : Video (5): vid-off 0x0@0.0  0k  (modescontroller says real is: Video (5): vid-off 0x0@0.0  0k )
1086.99 MC I: Delaying setting of media mode Video (5): vid-off 0x0@0.0  0k  because the RTP addresses are missing.
1086.99 MC !ER TransactionActionStorage::removeAction no match for Disconnect callstackid(5)
1086.99 SipMedia W: Got Update Req for non-existing call ID: 5
1087.01 DATACTRL I: DataGateCfgReq(ig=4) hdlc=yes
1087.01 MediaStreamController !ER MixerAudio::remove: wrong state
1087.02 MediaStreamController !ER MixerAudio::remove: wrong state
1087.04 IXUser I: iXController teardownIxChannel: Not connected
1087.05 MC I: CapabilityControllerImpl::setCapset() reduced = 0, waitForDuoGate = 0, hasLegacyVideo = 0
1087.06 RTP I: TrafficCtrl: Deleting entry (main): id: 32, tcid: 65568
1087.07 RTP I: TrafficCtrl: Deleting entry (duo): id: 34, tcid: 65568
1087.08 RTP I: TrafficCtrl: Deleting entry (duo): id: 38, tcid: 65569
1087.08 CAMERA I: CamVisca::Ready_doCAMActionReq cameraId=1 actionId=20
1087.08 MediaStreamController I: MV::getVCSetting getOutputPortStatus initialized 1
1087.09 MediaStreamController I: MV::getVCSetting localHwCookieHint_ 0 w 1280 h 720
1087.09 MediaStreamController I: MV::getVCSetting getOutputPortStatus initialized 1
1087.09 MediaStreamController I: MV::getVCSetting localHwCookieHint_ 8 w 1920 h 1080
1087.09 MC !ER TransactionActionStorage::removeAction no match for Modify  InGate  id(63)
1087.09 MC !ER TransactionActionStorage::removeAction no match for Modify  InGate  id(71)
1087.09 MediaServerMsctrl !ER Msf::createCnf(mx=65): No mixer
1087.10 MediaStreamController I: doAUDIOMIXERREMGATECNF(ms-ig=7) not found
1087.10 DATACTRL I: DataGateRemReq(ig=4)
1087.11 MediaStreamController !ER doVIDEOGATECONFIGURECNF(ms-ig=14) not found
1087.18 MediaStreamController I: MV::getVCSetting getOutputPortStatus initialized 1
1087.18 MediaStreamController I: MV::getVCSetting localHwCookieHint_ 0 w 1280 h 720
1087.18 MediaStreamController I: MV::getVCSetting localHwCookieHint_ 8 w 1920 h 1080
1087.22 CAMERA I: CamVisca::sendCAMPositionInd cameraId=1 pos=400/60/0/4576
1087.53 MediaStreamController !ER doVIDEOGATECONFIGURECNF(ms-ig=14) not found
1087.53 MediaStreamController !ER doVIDEOMIXERADDCNF(ms-mx=9) not found
1087.53 MediaStreamController !ER doVIDEOMIXERADDCNF(ms-mx=10) not found
1087.57 VIDEOCTRL-0 I: (proxy,161) maximum number of framestorage slices 2
1087.60 VIDEOCTRL-0 I: VIDEOCTRL_doReadyMixerConfigureReq: redundant signal for mixer (rawvideo,1) from (MSCtrl,0)
1087.60 VIDEOCTRL-0 I: VIDEOCTRL_doReadyMixerConfigureReq: redundant signal for mixer (rawvideo,2) from (MSCtrl,0)
1087.61 MC I: MediaServerAction(): InputGate(ig=76) creation took 557 miliseconds
1087.75 CAMERA I: CamVisca::sendCAMPositionInd cameraId=1 pos=400/60/0/4577
1088.28 CAMERA I: CamVisca::sendCAMPositionInd cameraId=1 pos=400/60/0/4578
1092.27 SipReg    Starting work timer (outboundindex: 0).
1092.57 SipReg    Executing SIPREG_Active_doSIPRegWorkTimeout.
1092.57 SipReg    Stopping work timer because we have nothing more to do.
1094.96 MC W: TransactionActionStorage::cbTimeoutAction: Modify  InGate  id(66)
1102.27 SipReg    Starting work timer (outboundindex: 0).
1102.57 SipReg    Executing SIPREG_Active_doSIPRegWorkTimeout.
1102.57 SipReg    Stopping work timer because we have nothing more to do.
!!! nothing
!!! nothing
!!! nothing
!!! nothing
!!! nothing
!!! nothing
1112.24 SipReg   Scheduling new keep-alive for proxy 10.10.40.2 in 30 seconds.
1112.27 SipReg    Starting work timer (outboundindex: 0).
1112.57 SipReg    Executing SIPREG_Active_doSIPRegWorkTimeout.
1112.58 SipReg    Stopping work timer because we have nothing more to do.
1122.27 SipReg    Starting work timer (outboundindex: 0).
1122.58 SipReg    Executing SIPREG_Active_doSIPRegWorkTimeout.
1122.58 SipReg    Stopping work timer because we have nothing more to do.
1132.28 SipReg    Starting work timer (outboundindex: 0).
1132.58 SipReg    Executing SIPREG_Active_doSIPRegWorkTimeout.
1132.58 SipReg    Stopping work timer because we have nothing more to do.
1142.24 SipReg   Scheduling new keep-alive for proxy 10.10.40.2 in 30 seconds.
1142.28 SipReg    Starting work timer (outboundindex: 0).
1142.58 SipReg    Executing SIPREG_Active_doSIPRegWorkTimeout.
1142.58 SipReg    Stopping work timer because we have nothing more to do.
1152.28 SipReg    Starting work timer (outboundindex: 0).
1152.58 SipReg    Executing SIPREG_Active_doSIPRegWorkTimeout.
1152.58 SipReg    Calling SIPREG_doRegister to refresh registration.
1152.58 SipReg    Setting status for regno 0 to 1, refresh=0 (cause: )
1152.58 SipReg   Not informing SipDialog about re-registration
1152.58 SipReg   Sending register request for sip:6019@10.10.40.2 to 10.10.40.2.
1152.58 SipReg    Starting work timer (outboundindex: 0).
1152.59 SipReg    Setting status for regno 0 to 2, refresh=90 (cause: )
1152.59 SipReg    Sending registration status to stack and SipUa.
1152.59 SipReg    Sending server status information upwards.
1152.88 SipReg    Executing SIPREG_Active_doSIPRegWorkTimeout.
1152.89 SipReg    Stopping work timer because we have nothing more to do.
1162.28 SipReg    Starting work timer (outboundindex: 0).
1162.58 SipReg    Executing SIPREG_Active_doSIPRegWorkTimeout.
1162.58 SipReg    Stopping work timer because we have nothing more to do.
1172.24 SipReg   Scheduling new keep-alive for proxy 10.10.40.2 in 30 seconds.
1172.28 SipReg    Starting work timer (outboundindex: 0).
1172.58 SipReg    Executing SIPREG_Active_doSIPRegWorkTimeout.
1172.58 SipReg    Stopping work timer because we have nothing more to do.
1182.28 SipReg    Starting work timer (outboundindex: 0).
1182.59 SipReg    Executing SIPREG_Active_doSIPRegWorkTimeout.
1182.59 SipReg    Stopping work timer because we have nothing more to do.
1187.14 ServiceControl I: ServiceControl: restart request received
1187.14 PROV   Provfsm: initiating de/re-registration triggered by CUCM service-control request!
1187.15 DnsLocator I: locatedAt() ipv4 unspec 10.10.40.2, port 536870911
1187.15 MWI I: on() subscribing to mailbox 1200@10.10.40.2 on behalf of sip:6019@10.10.40.2
1187.16 SipStack I: SipEv: Active Subscribe to '1200@10.10.40.2' of type 'message-summary', unsolicited=0
1187.16 SipStack I: SipEvNotify - Unsubsribing to sip:6019@localhost
1187.16 SipReg   SipRegisterReq: Trying to register '' (iRegNum=0) on '10.10.40.2' (bWaitForNewConfig=0).
1187.16 SipReg    Starting work timer (outboundindex: 0).
1187.16 SipReg   SipRegisterReq: Trying to register '' (iRegNum=0) on '' (bWaitForNewConfig=0).
1187.16 SipReg    Starting work timer (outboundindex: 1).
1187.17 SipReg    Starting work timer (outboundindex: 2).
1187.17 SipReg   SipRegisterReq: Trying to register '' (iRegNum=0) on '' (bWaitForNewConfig=0).
1187.17 SipReg    Starting work timer (outboundindex: 3).
1187.17 SipReg   SipRegisterReq: Trying to register '' (iRegNum=1) on '10.10.40.2' (bWaitForNewConfig=0).
1187.17 SipReg    Assuming work timer is actually started (outboundindex: 0).
1187.17 SipReg   SipRegisterReq: Trying to register '' (iRegNum=1) on '' (bWaitForNewConfig=0).
1187.17 SipReg    Assuming work timer is actually started (outboundindex: 1).
1187.17 SipReg    Assuming work timer is actually started (outboundindex: 2).
1187.17 SipReg    Assuming work timer is actually started (outboundindex: 3).
1187.17 SipReg   SipRegisterReq: Trying to register '' (iRegNum=2) on '10.10.40.2' (bWaitForNewConfig=0).
1187.17 SipReg   SipRegisterReq: Trying to register '' (iRegNum=2) on '' (bWaitForNewConfig=0).
1187.17 SipReg   SipRegisterReq: Trying to register '' (iRegNum=3) on '10.10.40.2' (bWaitForNewConfig=0).
1187.17 SipReg   SipRegisterReq: Trying to register '' (iRegNum=3) on '' (bWaitForNewConfig=0).
1187.18 SipReg   SipRegisterReq: Trying to register '' (iRegNum=3) on '' (bWaitForNewConfig=0).
1187.18 SipReg    Assuming work timer is actually started (outboundindex: 2).
1187.18 SipReg    Assuming work timer is actually started (outboundindex: 3).
1187.18 SipReg   SipRegisterReq: Trying to register '' (iRegNum=4) on '10.10.40.2' (bWaitForNewConfig=0).
1187.18 SipReg    Assuming work timer is actually started (outboundindex: 0).
1187.18 SipReg   SipRegisterReq: Trying to register '' (iRegNum=4) on '' (bWaitForNewConfig=0).
1187.18 SipReg    Assuming work timer is actually started (outboundindex: 1).
1187.21 MWI !ER reject() sip subscription failed. 489 Bad Event
1187.46 SipReg    Executing SIPREG_Active_doSIPRegWorkTimeout.
1187.46 SipReg    Calling SIPREG_doRegister in SIPREG_StateActivateNewValue upon SIP_REG_STATUS_REGISTERED.
1187.46 SipReg    Setting status for regno 0 to 3, refresh=0 (cause: )
1187.47 SipReg    Sending registration status to stack and SipUa.
1187.47 SipReg I: Sending deregister request for sip:6019@10.10.40.2 to 10.10.40.2.
1187.47 SipReg    Starting work timer (outboundindex: 0).
1187.47 SipStack I: Failed to find new default outbound proxy at present time.
1187.49 SipReg    Setting status for regno 0 to 0, refresh=0 (cause: )
1187.49 SipReg    Sending registration status to stack and SipUa.
1187.49 SipReg    Sending server status information upwards.
1187.49 MWI I: on() un-subscribing to unsolicited req URI sip:6019@localhost
1187.49 SipStack I: SipEvNotify - Unsubsribing to sip:6019@localhost
1187.50 SipStack I: SipEv: Active Subscribe to 'sip:6019@localhost' of type 'service-control', unsolicited=1
1187.50 SipStack !ER Failed to find flow for outbound proxy:
1187.50 SipReg   SipRegisterReq: Trying to register 'sip:6019' (iRegNum=0) on '10.10.40.2' (bWaitForNewConfig=0).
1187.50 SipReg    Assuming work timer is actually started (outboundindex: 0).
1187.50 SipReg   SipRegisterReq: Trying to register 'sip:6019' (iRegNum=0) on '' (bWaitForNewConfig=0).
1187.51 SipReg    Starting work timer (outboundindex: 1).
1187.51 SipReg   SipRegisterReq: Trying to register 'sip:6019' (iRegNum=0) on '' (bWaitForNewConfig=0).
1187.51 SipReg    Starting work timer (outboundindex: 2).
1187.51 SipReg    Starting work timer (outboundindex: 3).
1187.51 SipReg   SipRegisterReq: Trying to register '' (iRegNum=1) on '10.10.40.2' (bWaitForNewConfig=0).
1187.51 SipReg    Assuming work timer is actually started (outboundindex: 0).
1187.51 SipReg   SipRegisterReq: Trying to register '' (iRegNum=1) on '' (bWaitForNewConfig=0).
1187.51 SipReg    Assuming work timer is actually started (outboundindex: 1).
1187.51 SipReg    Assuming work timer is actually started (outboundindex: 2).
1187.51 SipReg    Assuming work timer is actually started (outboundindex: 3).
1187.51 SipReg   SipRegisterReq: Trying to register '' (iRegNum=2) on '10.10.40.2' (bWaitForNewConfig=0).
1187.51 SipReg   SipRegisterReq: Trying to register '' (iRegNum=2) on '' (bWaitForNewConfig=0).
1187.51 SipReg   SipRegisterReq: Trying to register '' (iRegNum=3) on '10.10.40.2' (bWaitForNewConfig=0).
1187.52 SipReg   SipRegisterReq: Trying to register '' (iRegNum=3) on '' (bWaitForNewConfig=0).
1187.52 SipReg    Assuming work timer is actually started (outboundindex: 1).
1187.52 SipReg    Assuming work timer is actually started (outboundindex: 2).
1187.52 SipReg    Assuming work timer is actually started (outboundindex: 3).
1187.52 SipReg   SipRegisterReq: Trying to register '' (iRegNum=4) on '10.10.40.2' (bWaitForNewConfig=0).
1187.52 SipReg    Assuming work timer is actually started (outboundindex: 0).
1187.52 SipReg   SipRegisterReq: Trying to register '' (iRegNum=4) on '' (bWaitForNewConfig=0).
1187.77 SipReg    Executing SIPREG_Active_doSIPRegWorkTimeout.
1187.77 SipReg    Calling SIPREG_doRegister in SIPREG_StateActivateNewValue upon SIP_REG_STATUS_INACTIVE.
1187.77 SipReg    Setting status for regno 0 to 1, refresh=0 (cause: )
1187.77 SipReg    Sending registration status to stack and SipUa.
1187.77 SipReg   Sending register request for sip:6019@10.10.40.2 to 10.10.40.2.
1187.77 SipReg    Starting work timer (outboundindex: 0).
1187.90 SipReg   SipReg SIP Auth: received
1187.90 SipReg   SipReg Number of Attempts=1 and Refresh timer=52
1187.90 SipReg    Setting status for regno 0 to 4, refresh=52 (cause: 401 Unauthorized)
1187.90 SipReg    Sending registration status to stack and SipUa.
1188.07 SipReg    Executing SIPREG_Active_doSIPRegWorkTimeout.
1188.08 SipReg    Stopping work timer because we have nothing more to do.
1192.29 SipReg    Starting work timer (outboundindex: 0).
1192.59 SipReg    Executing SIPREG_Active_doSIPRegWorkTimeout.
1192.59 SipReg    Stopping work timer because we have nothing more to do.
1192.90 DnsLocator I: locate(): we've failed, give up for now
1192.90 DnsLocator I: locatedAt() ipv4 unspec 10.10.40.2, port 536870911
1192.90 SipReg   SipRegisterReq: Trying to register 'sip:6019' (iRegNum=0) on '10.10.40.2' (bWaitForNewConfig=0).
1192.91 SipReg    Starting work timer (outboundindex: 0).
1192.91 SipReg   SipRegisterReq: Trying to register 'sip:6019' (iRegNum=0) on '' (bWaitForNewConfig=0).
1192.91 SipReg    Starting work timer (outboundindex: 1).
1192.91 SipReg    Starting work timer (outboundindex: 2).
1192.91 SipReg    Starting work timer (outboundindex: 3).
1192.91 SipReg   SipRegisterReq: Trying to register '' (iRegNum=1) on '10.10.40.2' (bWaitForNewConfig=0).
1192.91 SipReg    Assuming work timer is actually started (outboundindex: 0).
1192.91 SipReg   SipRegisterReq: Trying to register '' (iRegNum=1) on '' (bWaitForNewConfig=0).
1192.91 SipReg    Assuming work timer is actually started (outboundindex: 1).
1192.91 SipReg    Assuming work timer is actually started (outboundindex: 2).
1192.91 SipReg    Assuming work timer is actually started (outboundindex: 3).
1192.91 SipReg   SipRegisterReq: Trying to register '' (iRegNum=2) on '10.10.40.2' (bWaitForNewConfig=0).
1192.91 SipReg   SipRegisterReq: Trying to register '' (iRegNum=2) on '' (bWaitForNewConfig=0).
1192.92 SipReg    Assuming work timer is actually started (outboundindex: 1).
1192.92 SipReg   SipRegisterReq: Trying to register '' (iRegNum=2) on '' (bWaitForNewConfig=0).
1192.92 SipReg    Assuming work timer is actually started (outboundindex: 2).
1192.92 SipReg    Assuming work timer is actually started (outboundindex: 3).
1192.92 SipReg   SipRegisterReq: Trying to register '' (iRegNum=3) on '10.10.40.2' (bWaitForNewConfig=0).
1192.92 SipReg    Assuming work timer is actually started (outboundindex: 0).
1192.92 SipReg   SipRegisterReq: Trying to register '' (iRegNum=3) on '' (bWaitForNewConfig=0).
1192.92 SipReg   SipRegisterReq: Trying to register '' (iRegNum=4) on '10.10.40.2' (bWaitForNewConfig=0).
1192.92 SipReg   SipRegisterReq: Trying to register '' (iRegNum=4) on '' (bWaitForNewConfig=0).
1192.93 SipReg   SipRegisterReq: Trying to register '' (iRegNum=4) on '' (bWaitForNewConfig=0).
1192.93 SipReg    Assuming work timer is actually started (outboundindex: 3).
1193.21 SipReg    Executing SIPREG_Active_doSIPRegWorkTimeout.
1193.21 SipReg    Stopping work timer because we have nothing more to do.
1202.24 SipReg   Scheduling new keep-alive for proxy 10.10.40.2 in 30 seconds.
1202.29 SipReg    Starting work timer (outboundindex: 0).
1202.59 SipReg    Executing SIPREG_Active_doSIPRegWorkTimeout.
1202.59 SipReg    Stopping work timer because we have nothing more to do.
1212.29 SipReg    Starting work timer (outboundindex: 0).
1212.59 SipReg    Executing SIPREG_Active_doSIPRegWorkTimeout.
1212.59 SipReg    Stopping work timer because we have nothing more to do.
1218.34 SipStack !ER Failed to find flow for outbound proxy:
1222.29 SipReg    Starting work timer (outboundindex: 0).
1222.59 SipReg    Executing SIPREG_Active_doSIPRegWorkTimeout.
1222.59 SipReg    Stopping work timer because we have nothing more to do.
CUIL reboot request, restarting
Unknown message type: 4
tshell: Remote closed connection
