06-02-2015 06:18 AM - edited 03-18-2019 04:33 AM
I am searching for a solution to alter a SDP header to not send video capabilities to a SIP trunk provided by an ISP. The reason is that calls from a Cisco Jabber softphone fails for outbound calls, I receive a "media not acceptable here": inbound works fine.
Cisco Jabber => CUCM => SIP TRUNK => CUBE => ISP SIP TRUNK
Settiing up calls inbound works fine, using a cisco hardware phone (with no video capabilities) works fine for outbound calls. According to the ISP they do not allow that there is video capabilities in the SDP header!!!???? I want to make the ISP ignoring these SDP settings but that seems for them to be difficult. So, question is, can i remove the capabilities in the SDP header on the CUBE and if; how is that possible?
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 213.XX.XXX.XXX:5060;branch=z9hG4bK62E317
From: "Jabber Windows" <sip:+45721XXXXX@213.83.148.132>;tag=5745F70-18E2
To: <sip:+45292XXXXX@62.121.XXX.XX>
Call-ID: E28CBEEB-3AF11E5-8D17E122-602BEEE3@213.XX.XXX.XXX
CSeq: 101 INVITE
Timestamp: 1432735365
Content-Length: 0
*May 27 14:02:45.990: //3186/3CA341800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 488 Not Acceptable Here
From: "Jabber Windows" <sip:+4572XXXXXX@213.XX.XXX.XXX>;tag=5745F70-18E2
To: <sip:+452XXXXXXX@62.121.XXX.XX>;tag=hjVZ_.7DBhf3h7cA
Call-ID: E28CBEEB-3AF11E5-8D17E122-602BEEE3@213.83.148.132
CSeq: 101 INVITE
Content-Length: 0
Reason: X.int ;reasoncode=0x0000032D;add-info=05CC.0001.0004
Best regards
Brian
Solved! Go to Solution.
04-04-2020 03:24 PM
Yah, you're right. Good point of view.
But in my country we usually don't use video at all. And we usually have problems with the carriers because that. So the faster solution is to remove it directaly from devices.
But the best manner to workaround it, is certanly forcing audio to the dial-peers as you sugest, and leave the video capabilities to others options.
We already have here many options and workarounds depending what is better for each cenarium and the needs of each situation.
Good work. Congratulations to everyone!
