04-24-2012 10:15 AM - edited 03-17-2019 11:06 PM
We have a number of CTS-1300's which work great, however when sharing PC displays during a call the PC's screen is shown in a small window at the bottom of the CTS screen, which is often too small to be seen by the participants.
Is there any way to increase the size of the presentation window up to near (or total) full screen whilst in a call?
Solved! Go to Solution.
04-24-2012 11:23 AM
You You can use the SWAP softkey in the PiP ctrl. This will make the presentation appear larger on screen than the video image. You can toggele back and forth to a larger video image. Must be using 1.7.1 and MIDlets. Hopefully this helps.
http://www.cisco.com/en/US/products/ps8332/products_user_guide_list.html
V/R,
JD King
04-24-2012 11:23 AM
V/R,
JD King
04-25-2012 12:39 AM
Thanks for your reply Jeff, it was most helpful.
Unfortunately our endpoints, whilst running midlets, are still on code 1.6.4 so I think an upgrade is in the pipeline!
