ā04-28-2016 07:49 AM - edited ā03-18-2019 05:52 AM
Hi Everybody,
I'm working on a TMS v 14.6.2, I have a task to upgrade about a 100 Tandberg Profile C20 endpoints to a version TC7.3.5.
Can you, guys tell me how to perform an upgrade in bulk on these Tandberg Profile 42 C20 using the TMS?
Thank you, guys, in advance.
Amine
Solved! Go to Solution.
ā04-28-2016 01:08 PM
On the System Upgrade page you have the ability to sort by specific endpoint types or software versions among various other filters, that should allow you to upgrade the specific endpoints you want easily.
ā04-28-2016 08:22 AM
At a high level, the process is:
Refer to the "Upgrading Cisco TMS-managed endpoints" section of the TMS 14.6 Admin Guide on pg 78 for detailed steps.
ā04-28-2016 01:03 PM
Hi Patrick,
Thanks for the precious instructions.
I know this procedure, the thing is that I want to know if there is a way to perform this upgrade in a CSV kinda way, the endpoints in interest are in different folders, there are about a hundred endpoints and they're all Tandberg Profile 42 C20.
Plus, I didn't manage to perform research based on the device type.
Is there a such way yet?
Thanks again, Patrick.
ā04-29-2016 12:20 AM
Thanks Patrick for the precious tip, TMS is an amazing tool, for real.
