hwic_t1e1_wic_bp_disconnect: disconnect failed
horance
Hi , I replace voip router from Cisco 3640 to C2921 router.
The C2921 had show error message.
%FLEXDSPRM-3-TDM_CONNECT: failed to connect voice-port (0/0/0) to dsp_channel(0/0/4)
I found this is a bug.
https://tools.cisco.com/bugsearch/bug/CSCuj64211
Known Fixed Releases:
(4)
15.4(1.3)T
15.4(1.4)T
15.4(1.8)S
15.4(1.9.1)XEB
Those version of IOS images do exist? i cannot find them.
Thanks.
Hi Horace,
even though15.4.1T1 image uploaded on 2921 router is not deferred but 15.1.4M7 is the latest and suggetsed image with same DRAM and flash requirments.
also DSP firmware 36.1.0 working on your router is above 35.1(2)DSP.Lastly, images available in which problem is fixed are not available for downloading.
you can give a try upgrading the IOS image on router to 15.1.4M7
http://software.cisco.com/download/release.html?mdfid=282774229&flowid=7443&softwareid=280805680&release=15.4.1T1&relind=AVAILABLE&rellifecycle=ED&reltype=latest
regds,
aman
Aman Soi
Hi Horance,
I think bug talks about DSP firmware.
can you run the command show voice dsp group all /show version and share the output?
regds,
aman
Hi aman,
  Thanks support.
#sh voice dsp group all
DSP groups on slot 0:
dsp 1:
  State: UP, firmware: 36.1.0
  Max signal/voice channel: 32/32
  Max credits: 480, Voice credits: 480, Video credits: 0
  num_of_sig_chnls_allocated: 32
  Transcoding channels allocated: 0
  Group: FLEX_GROUP_VOICE, complexity: FLEX
    Shared credits: 480, reserved credits: 0
    Signaling channels allocated: 32
    Voice channels allocated: 0
    Credits used (rounded-up): 0
  Slot: 0
  Device idx: 0
  PVDM Slot: 0
  Dsp Type: SP2600
dsp 7:
  num_of_sig_chnls_allocated: 28
    Signaling channels allocated: 28
  Slot: 0
  Device idx: 0
  PVDM Slot: 1
  Dsp Type: SP2600
router show version:
#sh ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(1)T1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Wed 12-Feb-14 04:57 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
pnc_chungho_voip uptime is 8 minutes
System returned to ROM by reload at 13:02:13 TPE Thu Feb 27 2014
System image file is "flash0:c2900-universalk9-mz.SPA.154-1.T1.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2921/K9 (revision 1.0) with 479232K/45056K bytes of memory.
Processor board ID FGL175210C8
3 Gigabit Ethernet interfaces
1 terminal line
2 Channelized E1/PRI ports
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*1        CISCO2921/K9          FGL175210C8
Technology Package License Information for Module:'c2900'
Technology    Technology-package                  Technology-package
              Current              Type           Next reboot
ipbase        ipbasek9             Permanent      ipbasek9
security      None                 None           None
uc            uck9                 Permanent      uck9
data          None                 None           None
NtwkEss       None                 None           None
CollabPro     None                 None           None
Horace
Hi Horace,
regds,
aman
