Ingress disconnected the call - Telepresence conductor
Nizamuddin Syed
The CUCM routes the call to conductor and the call gets disconnected and when checked in the conductor observe the disconnect reason as Ingress call disconnected. Any clue how to move fwd with this issue ?
Conductor version :    XC 2.0.2
CUCM : 8.6.2
Device type : tandberg EX60
15 Replies 15
Paulo Souza
Are you having this issue for only this particular endpoint? Do other endpoints work? Have you integrated Conductor to CUCM by following Cisco deployment guide? What is the version of your TP Server?
Paulo Souza
Please rate replies and mark question as "answered" if applicable.
Paulo Souza Was my response helpful? Please rate useful replies and remember to mark any solved questions as "answered".
not all the endpoints have issue,but a few are facing them and the issue is intermittent. Yes, using the help of the deployment guide we have setup this environment. TPS is on X 7.2.1
Version X7.2.1 is related to VCS, no to TP Server. Can you confirm the version of TP Server? Also, can you provide further information about your environment? is there VCS involved? Conductor is integrated with VCS or CUCM? If it is integrated with VCS, which deployment is being used, CPL or B2BUA?
Please, provide further information. =)
Paulo Souza
sorry. the tps is on 3.0(2.48). Yes, VCS is involved. The conductor is integrated with CUCM.
When teh call fails, could you check the logs in TP Server to see the disconnection reason? Also, try check the logs in Conductor to see the disconnection reason.
In addition, is your endpoints registered to CUCM using SIP, right? Are they running TC 5 or later version? Are they registered to CUCM according to Cisco documentation?
Paulo Souza
The TPS shows the reason :destroy at far end request; remoteTeardown
Conductor shows the reason : Ingress disconnected the call
The endpoint is registered to VCS and on version TC6
Hi Nizamuddin,
The case involved some log captures and analysis. i would advise you to open the TAC case for faster resolution.
Rgds
Alok
Thank you Alok. Will do it shortly
I agree with Alok.  =)
You can open a TAC case from this discussion, so TAC will have a initial history of your case, this can be helpfull.
Please, after TAC find a solution (they always find ), please, post the result here, because your issue may be helpfull for another people in the community.
Paulo Souza
Hi Nizamuddin,
i think the call flow here is
ex60<--SIP-->VCS<--sip trunk-->CUCM<--sip trunk-->condcutor<--SIP-->TPS
right?
in this case you must be seeing a disconnect on the VCS also?  what is the error there? looks like some thing going wrong in between the signaling passing through many infrastructure device.
what is the error on VCS? a quick logs on VCS will give you more idea of who's sending disconnect and then you can devide the call leg in two and start troubleshooting the end which is having a problem.
anyways a TAC case would be a good idea in this scenario.
Rgds
Alok
In addition to what Alok suggested, I am thinking... If your endpoints are registered to VCS, why is your Conductor integrated to CUCM and not to VCS? Any particular reason for that?
I am not saying it is wrong, I am saying it is not common.
Paulo Souza
we have CTS endpoints registered to CUCM  and Tandberg to VCS. We are in a process to migrate them to CUCM.
Yes, the flow is correct. I am not able to find any reason on the VCS.
I have the same problem as you "destroy at far end request; remoteTeardown... " in the following environnement :
EX90 <===> CUCM 9.1 <==> XC2.2 <==> Multiparty 320.
Or did you fix it ?
Have a nice day!
Alexandre
