Showing results forĀ
Search instead forĀ
Did you mean:Ā
Installation TMS PE Migration Tool
rasimyigit
Hi All,
i have one Problem:
I have installed the TMS Server 13.2.2.Then I wanted to install the PE tool . I have type all necessary data and credentials like TMS server credentials and SQL Remote credentials on the installation Progress of this PE Tool. Every time this error comes up "please check the SQL Protocols".
There are 4 parameters on the SQL site what we could to set:
= Shared memory : enabled/disabled?
= Named Pipes: enabled/disabled?
= TCP/IP:           enabled/Disabled?
= VIA:                enabled/disabled?
which 4 parameters must be set  to the PE tool can be installed successfully or to connect the SQL Database of the Remote SQL Database?
We cant install the PE Tool.
THX for your feedback
Magnus Ohm
Great and no problem, please set this thread to resolved then :)
12 Replies 12
Magnus Ohm
Try to enable the sql browser service on the sql server.
/Magnus
Hi Magnus,
nice to see you again.
Ok, but no changes on
Only the service SQL Browser?
And also note page 7 of the TMSPE Deployment Guide concerning SQL Server Connnection:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/tmspe/install_guide/Cisco_TMSPE_Deployment_Guide_1-0.pdf
And if using Named Pipes only, also note the comments directly under the SQL Server Connection comments, i.e. Windows Server.
Hi ,
just see that was a new Deployment Guidepublished, in this, it is also in there with the SQL settings.
Will try it out, thank you for first
Hi gagain,
now the SQL Browser Service is working and the installation progress comes a step further. During the installation, the operation interrupts  with a unkwown error. I've check the logfiles but it is little bit tricky.
Any ideas?
Hi Rasim
So it starts to install, correct? And the installation finished prematurely is that correct? Does it do the roll back under the database configuration or on the web application setup? What is the text in the installaller like "Configuring Database" and then it switches to "Rollback action" or something similar, I am just guessing as I don't remember the exact writing in there at this time. But that might give us a clue on what is going on. For example I have 3 different "possible" issues that you might encounter based on what we have seen.
1. Are you using any special characters in the SQL password?
2. Did you precreate the TMSPE database before installing TMSPE? (Make sure the database name is 'tmspe') case sensitive.
3. User access and database permissions, if you did not pre-create the database and the user that you are connecting with is going to create the database for you, then you must be sure that the user has sufficient permissions. In the installer log file, search for a word "master". If you find the word, does it say something about permissions? If it does, then you need to give the user more permissions and run the installer again.
/Magnus
Hi Magnus,
the installation was after create the database name with lower case name successfully.
The Migrations Tool is always not successfully. But doesnt matter because i have a new clean installation of the TMS Server with greenfield
What is immediate, if you go to provisioning -->User to create some Folders for Movi's ect.. i miss the root folder.
Could that be, because no VCS control is installed now yet. Usually a root folder but should be there without VCS Control?
THX
Magnus Ohm
You dont need to run the migration tool if its a clean install..
Did you run it successfully after installation with an empty opends database? Did you follow the steps for a clean install in the deployment guide?
/Magnus
Yes
Yes
The openDS was empty, we created a second db with tmspe. The PE Tool said, do want use the existing database.during the installation..i decided=yes. But  why is the root Folder not in the Provisioning user? i cant created any Folders like Movi ect..
Magnus Ohm
Hi, the root folder should be there... Are there any errors? Do you see the gui? Try another browser maybe? But check the provisioning extension logs and the provisioning extension diagnostics what does it say?
/Magnus
rasimyigit
Hi Magnus,
Sorry for the late feedback. One restart of the tms server fix this problem. After the reboot, I was able to set or configure the root folder.
Thank you very much for patients
Magnus Ohm
