02-26-2009 07:09 AM - edited 03-17-2019 09:39 PM
I have to hook up our CME to an interfom. I am assuming i need fxo ports and a dial plan that sends calls to that fxo port. Then into the intercom.. Is this theory correcT?
02-26-2009 07:49 AM
Hi Mike,
This is indeed the correct theory :) Just check the maufacturers specs to determine if an FXS (where you just dial up a station DN) should be used over FXO. This is a good thread that discusses these thoughts;
Hope this helps!
Rob
02-26-2009 08:17 AM
great thanks
