08-29-2012 01:22 AM - edited 03-17-2019 11:41 PM
I am trying to setup an Intercompany trunk from our VCS StarterPack Express to a parner company Lync via Internet. They are serving different domains. No VPN between the internal networks. VCS StarterPack Express is essentially an Expressway and is with public IP address.
The goal is to be able to make video calls between the two domains.
I've thoroghly read the Solution and Deployment guide, but all examples are with VCS control and shared domains. Also it seems that the internal networks are visible as they are in the same company.
Is that possible? Any guidelines?
I've tried with and without B2BUA pointing to the public Lync address, but no luck. VCS always get a 404 reply. Also Lync is configured as in the guide.
08-29-2012 02:51 AM
first thing this implementation is not supported or tested. standard deployment is to have VCS control and expressway setup to do this.
However being in a impl role earlier, i know how customer req changes with time and sometimes you have to go out of the way to meet them.
you can definitely give a try as i don't know if there is a limitation for doing this!!becuase expressway also has B2BUA application..
A 404 error is "not found". not sure when you are getting this error but when you have the vcs B2BUA pointing to Lync does the connection shows active and alive?? till time you make the connection alive we didn't achieved any thing.
a point to start is make the Lycn and VCS setup alive using the TLS and then configure the necessary routes..
but this requires ports to be opened if you have firewall and you should consider the delay and the security issues of the internet.
Without B2BUA integration we see lots of video issues and considering the internet and delay i don't suggest to go for without B2BUA.
Best of luck for the deployment.
Alok
08-29-2012 04:21 AM
Thanks for the answer and clarification regarding support of this solution. I've not found such a statement anywhere in docs.
With the B2BUA application i get to "Unknown failure" status.
Looking at the VCS and Lync logs i see that VCS sends OPTIONS SIP packet to Lync and Lync replies with 404 with reason "From and To domain combination invalid" (by memory)
I am setting it up with TLS, but with TCP it's the same issue.
I suspect invalid configurion in the Lync, but i have no administrative access to it. I have only sent the deployment guide to the Lync Administrator and he says that everything is configured.
He used thess examples:
New-CsTrustedApplicationPool -Identity vcs.ciscodomain.com -ComputerFqdn vcs.ciscodomain.com -Registrar feppool.msdomain.com -site 1 -RequiresReplication $false -ThrottleAsServer $true -TreatAsAuthenticated $true
New-CsTrustedApplication -ApplicationId VCSApplication1 -TrustedApplicationPoolFqdn vcs.ciscodomain.com -Port 65072
Enable-CsTopology
vcs.ciscodomain.com is resolveable to our VCS's public IP. this is in the VCS server certificate as well.
Is there anything special that should be configured on the Lync side?
I have installed the Lync's CA certificate in VCS so there should be no certificate issues.
In this configuration the B2BUA signaling dest address should be the Lync Edge Server public hostname, right?
08-29-2012 04:57 AM
you can't really apply the configuration steps intended for a regular VCS-C/B2BUA deployment for this "experimental" deployment, and as Alok states, what you are attempting to do is neither supported nor tested.
That being said, on a general note, for any communication between a Lync Edge server and a foreign device (Such as the Lync Edge server of a remote company), the way to make the Edge server even attempt to communicate back properly to the foregin device is by means of federation, that goes for all Lync traffic via a Lync Edge. The "From and To domain combination invalid" message you are seeing indicates that federation has not been properly set up between the Lync domain in question and the SIP domain used by the foregin device, in this case the VCS Expressway.
There is in any case no point in adding trusted applications or application pools for a deployment where you will be communicating with the Lync environment through its Edge server, federation would be the way to go then, but as I mentioned initially, this type of deployment is not something that has been tested for the VCS and is therefore not supported.
Happy testing
- Andreas
08-29-2012 06:23 AM
Thanks Andres. Your post really helped me understand the picture.
One more question:
Quote from page 16 of Cisco_VCS_Microsoft_OCS_2007_R2_and_Lync_2010_Deployment_Guide_X7-1:
OCS/Lync deployments may also contain Edge servers to allow MOC/Lync clients to register from outside the local network through the Edge server to OCS/Lync. Communicating with MOC/Lync devices outside the edge server requires both the Edge Server and the VCS Expressway connecting to the public Internet. (Calls involving a Microsoft Edge server require the VCS to have the Enhanced OCS Collaboration option key installed, as this key allows for ICE to be used for media connectivity, which is required in this scenario.)
Am i 100% required to have the Enhanced OCS Collaboration option key installed to be able to realize that?
08-29-2012 06:33 AM
I can't really answer that question, since what you are attempting to deploy is entirely outside the scope of our OCS/Lync deployment guides.
In general, the Enhanced OCS Collaboration option key enables two features on the OCS/Lync B2BUA:
1) It enables the B2BUA to use encrypted RTP media (SRTP) between itself and OCS/Lync
2) It enables the B2BUA to use TURN services with a TURN server, which is required for connectivity with OCS/Lync clients connected via an Edge server, when integrating OCS/Lync with a VCS Control
I guess that for your theoretical deployment, point 1) would apply while point 2) would not really be applicable since no VCS-C would be in the mix.
Again, this is just theoretical and I wouldn't recommend having any expectations of getting this solution to work.
- Andreas
08-29-2012 06:41 AM
I just came across this vedio and thought to share..!!
again its talking about creating lync fedretion between company A and B edge server as pointed by Andeas!!
http://www.youtube.com/watch?v=5IMkFxMwnwg
Cheers,
Alok
08-29-2012 03:38 PM
Hi!
Yea, the video shows the pretty standard deployment, so this should possibly work for most federated deployments
when they have their own internal (gw)-vcs with b2bua.
In general the standard deployment is that the customer with the lync install wants to use a vcs
in his network to enable standard based endpoint communication. lync2lync in between organizations
would always go via edge&federation.
From how I understood the case here, its the remote organization which wants to talk directly VCS2edge.
By today I would say, thats the right idea, but at least not scalable. Without b2bua anyhow the good old
freezing problem would occur and with the remote domain would need to be added and the b2bua only
supports one domain. Besides other problems which might lock it up.
So this looks more like a feature request to me, but I am in as well on it: +1
