internal movi login problem with starter pack
rashmi.kumari
Hi all!
I am trying out to configure the VCS Starter Pack Express Version:          X7.0.1
I've followed the Cisco_VCS_Expressway_Starter_Pack_Deployment_Guide_X5-1 guide.
All of the steps are done. All necessary DNS configurations are done as well.
Cluster name: vcss.example.com
SIP domain name: example.com
Local host name: vcs
Domain: example.com
3 users are created.
Movi settings:
username: test
password: test123
SIP domain: example.com
Movi says:
Wrong username, domain and/or password. Check spelling and Caps Lock.
But those are right! I have chacked them many times.
Logs are in attachment.
awinter2
Level 7
Level 7
Hi Rashmi,
did you make sure to create local database user credentials for user test, and have you configured your Default Zone to 'Check credentials'?
Have you created the 'example.com' SIP domain on the VCS?
Hi Andreas,
Already created users in local database
created example.com sip domain on vcs
when i configured default zone to  check credentials ,its not showing any result of login
only showing regsitering at ip address of vcs starter pack
regards
Rashmi
Rashmi,
if the Movi client is displaying 'Registering at x.x.x.x' that indicates that provisioning is working. If the Movi client fails to register, you might want to check that the Movi client can reach the Expressway on TCP ports 5060 and 5061.
If you aren't able to resolve the problem otherwise, I recommend that you open a case with TAC for further troubleshooting, since this will require taking some logs from the Expressway and Movi client.
Best regards
Andreas
