IP registration
papa45us1
I set the IPs for the IPv4, gatekeeper, gateway and subnet mask via RS232 but the C40 will not keep these setting, even after rebooting the codec.
What do I need to do or check on?
Sergio Quezada
You can simply create a Startup script (using Xconfiguration commands). I have attached the Admin Guide as well as the API commands. Hope this helps.
