06-27-2018 05:38 AM - edited 03-18-2019 02:12 PM
On the SX80 I can change the input from mic to line. The Room kit plus does not have this option. Is it possible to add an audio line in from for instance a laptop or audio mixer or will it bring damage to the mic. port?
I was thinking about a Sennheiser KA600i microphone cable to connect to anything I want using the XLR connector.
Solved! Go to Solution.
06-27-2018 08:52 AM
Sure, all you need is a line level to mic level adapter. See here on Amazon, plenty of options:
06-27-2018 08:52 AM
07-17-2018 08:53 PM - edited 07-17-2018 09:01 PM
All that does is attenuate the signal by 50dB. If you can do that from whatever you are using to generate the signal in the first place then that would save having to purchase additional hardware.
Please remember to mark helpful responses and to set your question as answered if appropriate.
