Message camera not conected
jmoreno1
Hello
I have a sx80 cisco installed and a non-cisco camera in the camera input connected.
In the background the camnara not conected message appears, but if the input source is displayed.
How can I remove the message
Thanks in advance
PJMack
Level 7
Level 7
Take a look at this thread on the subject, it gives you some ideas depending on what SW you are using, what inputs you're using, etc. You should be able to find a way around it.
https://supportforums.cisco.com/t5/telepresence/cisco-sx80-removing-no-camera-connected-warning-from-osd/td-p/2786574
I know that under the newer software versions (I checked a CE9.4.0 endpoint), you can get rid of the message by setting the Peripherals > Profile > Cameras setting from the default "Minimum1" to "0".
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
