isdn link in korea
Russell Haney
I am having a problem setting up the ISDN Link with a new SX20 here in Korea. Will the PRI-E1 settings will work here?
I have attached the config files
HI Russell,
The config file you've posted is only the xconfig output from the SX20... do you have the xstatus of the SX20 and the xconfig and xstatus from the ISDNLink?
Have you paired the ISDNLink and the SX20 correctly?  At a quick look at the SX20 config you've posted, I can't see that has paired properly..
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Wayne,
I will try to get the rest of files. But the Link and codec are paired and talking to each other. The PRI config doesn't give me many options for switch type. I set it for Euro since they use E1 channeling here. The ISDN link is giving me a layer 2 alarm.
I don't have one connected to a PRI that I can get to to check from here, only ones on BRI connections, so I'm working from memory... Have you configured all the PRI E1 settings on the ISDNLink
  • NetType:PRI
  • SwitchType: Euro
  • HighChannel: 31
  • MaxChannels: 30
  • NumberRangeStart: The start number of your ISDN number range
  • NumberRangeStop: The end number of your ISDN number range
Wayne
Wayne
Yep, done that.
I have a trouble ticket in with the Telco just in case they turned off the service.
