Tanderg 95 MXP
nocsv0001
Friends I need your valuable assistance, it happens that reset my camera tandberg 95 MXP and I delete the key features and bandwidth option as shown in the image. Use the command: defvalues set [all / audio / factory]. For this reset I can no longer make any video and generates me
The network option is not installed, install the wide choice of network band.
As I can Retrieve the option key?
Thank you very much.
Amigos necesito de su valiosa ayuda, sucede que resetee mi camara tandberg 95 MXP y me borro las features and bandwidth option key tal como lo muestra la imagen. Utilice el comando: defvalues set [all/audio/factory]. Por dicho reseteo ya no puedo realizar ninguna videoconferencia y me genera
la opcion  de red no esta instalada, instale la opcion ancho de banda de red. Se los agreadeceria su ayuda. Mil Gracias
tandberg edge 95MXP
2 Accepted Solutions
You can lookup license keys using the Cisco License Portal > Get Other Licenses > TelePresence License to Resend.  Enter the serial number, and if the serial number is in Cisco's database, it should return the license information.
If you're using the web interface, under Upgrade, there is the bandwidth and option fields to enter the keys.
If you're using SSH, use the following commands:
xConfiguration OptionKey Features
xConfiguration OptionKey Bandwidth
5 Replies 5
nocsv0001
Thank for you help!!
Now, where I enable Installed Options: MultiSite and Presenter?
Regards!
Done :)
I can see enabled, again thank you very much for your help.
Regards!
