Issue Expressway with Smart licensing (SSM-On Prem)
failed registration between SSM-on prem and expressway with reason:
Failure reason: SSL: no alternative certificate subject name matches target host name 'CCSSMS.bfegy.com'
I have assigned a cert for SSM and uploaded it to EXP's trust CA.
but it shows that the certificate is "Not a CA" as below, I don't know if it is a problem or not.
I have opened the firewall ports HTTPS 443 between both.
the Expressway for smart licensing configuration is as below:
13 Replies 13
b.winter
As the error message already declares:
You only should upload CA certificate, that signed the cert of the SSM and not the cert of the server itself.
Have you tired with IP address ?
Sign the SSM certificate with an CA and upload the CA root to the Expressway C.
Response Signature
I have already uploaded the root CA that signed the SSM cert to the expressway trust store.
i have tried with :
https://<<fqdn>>/Transportgateway/services/DeviceRequestHandler
https://<<fqdn>>/SmartTransport
https://<<iIP add>>Transportgateway/services/DeviceRequestHandler
https://<<IP add>>/SmartTransport
but the only works is:https://<<fqdn>>/SmartTransport and the others give invalid URL as the below :
It should be the following format: https://<<fqdn>>/SmartTransport. So it should be fine.
IP-address wouldn't work, since it isn't in the cert normally and therefore would give a cert error.
Have you delete the CSSM cert from the trust store?
Have you tried a reboot?
yes, i have done that, delete the cert of SSM from expressway trust store and leave only the ROOT
restart and try,, reboot and try ...and no hope
it still detects error as below:
Smart Licensing is ENABLED
Registration:
Status: REGISTERING - REGISTRATION IN PROGRESS
Export-Controlled Functionality: NOT ALLOWED
Initial Registration: FAILED on Jan 24 2022 13:54:05 EET
Next Registration Attempt: Jan 24 2022 14:13:28 EET
Although I have double-checked the cert and alternative certificate subject name:
 https://<<fqdn>>/SmartTransport is the correct url. Just to check the behavior of expressway, i requested to try with   IP,
What version of expressway and SSM you use ? looks like you might need a TAC support.
Response Signature
eliegerges
Hello Abdelrahman,
How this issue was resolved cause i am having the same behavior.
Thank you
if you are using https://fqdn then make sure your certificate has the FQDN. if not try with https://IPaddress.
Also make sure you have ports  opened
Register product instances to the SSM On-Prem. See Registering Product Instances to the On-Prem
in the Cisco SSM On-Prem User Guide and the documentation for your product.
• Cisco Products use the following API endpoints:
o HTTPS(443): tools.cisco.com. (Registration/Authorization)
o HTTP(80): www.cisco.com
• Smart Software Manager On-Prem uses the following API endpoints:
o User Interface: HTTPS (8443) Only
o Products: HTTP (80)/HTTPS(443)
o CSSM: HTTPS (443)
▪ Syncs:
api.cisco.com. (6.2 and prior)
swapi.cisco.com (6.3 and later)
▪ Account Registration: cloudsso.cisco.com
o cloudsso.cisco.com
Response Signature
Marc Brauner
You should open port 443 and 80 in your firewall
It does not use port 80. We’re using SL on our Expressways and do not have port 80 open in the firewall for the E to communicate with the on-prem SSM.
Response Signature
Port 80 needs to be open in version 14.0.6 of EXP (I have not testet with other versions). It dosen't make sense i know, but i have debugged on the error for a week and after we open port 80, it starts to work.
We use a newer version that that and we do not have port 80 open from the E’s to the on-prem SSM.
Response Signature
