08-05-2013 06:17 PM - edited 03-18-2019 01:34 AM
I have a recording which has got a few errors and are wondering if there is anyway to rescan\reprocess from the original rtp dump.
Symptons:
1. If you select Manage Outputs on the problem recording first error noticed is it come up with Recording Call Speed = 0 kbps and recorded with daul stream = no (originally this was not the case).
2. Get transcoder errors see details from log file:
8039 2013-08-06T11:00:39+10:00 Info: Initializing transcoding - Configuring job
8040 2013-08-06T11:00:39+10:00 Info: Finding job information [job_id = A9BCBA29-82CC-4164-B8F0-230BE467F171, template = <transcode conference_id="ee86be24-08e0-460f-856b-20561d8dd6a6" thumbnail_path=""><clips action="transcode"><input filename="\\fsact02-cdc\Telepresence\data\rtpdumps\EE86BE24-08E0-460F-856B-20561D8DD6A6000.ogg" points="0" hasvideo="True" framerate="0"/></clips><metadata name="Chief's Talk" speaker="" copyright="" keywords="" description="" date="1374638400"/><writer source="normal"><template codec="windowsMedia" delivery="DELIVERY_ON_DEMAND" qualitybitrateK="0" layout="sidebyside" piplocation="top/left" quality="Large"/><output type="file" guid="bbef76ed-0d93-4318-88fa-a3b78c4770e9" directory="\\fsact02-cdc\Telepresence\data\media\"/></writer><callinfo bitrateK="0" hasaudio="false" hasextended="false" hasvideo="false" videoFrames="0" extendedFrames="0" duration="1"/></transcode>]
8041 2013-08-06T11:00:39+10:00 Warning: Setting output bitrate and size, Zero call bitrate - Using 2 Mb/s
8042 2013-08-06T11:00:39+10:00 Info: Transcode settings [extended_frame_rate = 0, extended_size = 0x0(), layout = 2, main_frame_rate = 0, main_height_ratio = 1, main_size = 0x0(), negotiated_bitrate_kbps = 0, output_bitrate_kbps = 2662, output_frame_rate = 30, output_frame_rate_max = 30, output_size = 0x0(), quality = 3, quality_bitrate_kbps = 0]
8043 2013-08-06T11:00:39+10:00 Info: Setting up template [job_id = A9BCBA29-82CC-4164-B8F0-230BE467F171] - Template set up
8044 2013-08-06T11:00:39+10:00 Info: Finding conference ID [conference_id = ee86be24-08e0-460f-856b-20561d8dd6a6, job_id = A9BCBA29-82CC-4164-B8F0-230BE467F171]
8045 2013-08-06T11:00:39+10:00 Info: Loading source rtp dump file [conference_id = ee86be24-08e0-460f-856b-20561d8dd6a6, job_id = A9BCBA29-82CC-4164-B8F0-230BE467F171] - Rtp dump source file loaded
8046 2013-08-06T11:00:39+10:00 Info: Getting template information [conference_id = ee86be24-08e0-460f-856b-20561d8dd6a6, job_id = A9BCBA29-82CC-4164-B8F0-230BE467F171, writer = Windows Media, writer_index = 0] - Found writer
8047 2013-08-06T11:00:39+10:00 Info: Reading rtp packet control message, Recording does not have video [job_id = A9BCBA29-82CC-4164-B8F0-230BE467F171] - Ignoring recording pause
8048 2013-08-06T11:00:39+10:00 Warning: Creating finish transcoding job request, Cannot determine duration [conference_id = ee86be24-08e0-460f-856b-20561d8dd6a6, job_id = A9BCBA29-82CC-4164-B8F0-230BE467F171] - Setting duration to last time seen by RTP handlers
8049 2013-08-06T11:00:41+10:00 Info: Receiving finish transcoding job response [conference_id = ee86be24-08e0-460f-856b-20561d8dd6a6, job_id = A9BCBA29-82CC-4164-B8F0-230BE467F171, kbps = 0, total_bytes = 0, total_milliseconds = 42] - Found job data
8050 2013-08-06T11:00:41+10:00 Info: Calculating percentage of real time taken to transcode [conference_id = ee86be24-08e0-460f-856b-20561d8dd6a6, job_id = A9BCBA29-82CC-4164-B8F0-230BE467F171, percent = 0] - Percentage found
3. video could be played back before editing (Content editor).
08-18-2013 05:25 AM
what version of TCS are you using?
do you see the frist snapshot of the recording on the TCS recording page?
do you know which codec used to do the recording (i.e. H263, etc.)?
