IX5000 via Conductor only 1 Screen only working
Dear All
I have the following Situation:
If I made a Call via Conductor only 1 screen on the IX5000 is active, but in selfview i can see all the screen is connected and active.
call made - (IX5000,SX80,SX20,DX70) call Conference via --> Conductor -->TP 8710
conductor - conference template configured maximum screen 3
quality configured - fullhd multichannel
Any Idea or Input appreciated !
Ashiq
Alok Jaiswal
Level 4
Level 4
Under the conference template in conductor under advanced setting have you enabled
  • Enable iX protocol
  • Multiscreen layout
I am assuming your call control is CUCM, check if you have enabled the below on the SIP Profile.
  • Allow iX Application Media and Allow multiple codecs in answer SDP are checked
  • SDP Transparency Profile is set to Pass all unknown SDP attributes
And on the CUCM under device settings multistream mode is set to AUTO.
Alok
Dear Alok,
Thanks for your response. I tried with after the changes made as per your comments , but the issue is same . I am able to see the self view for the 3 screen when calls are not there.
dear Alok,
any update . kindly advise if anyother options i can try to work it.
Ashiq
