03-27-2015 09:59 PM - edited 03-18-2019 04:16 AM
Hello Team,
We would like to deploy cisco jabber video in our existing infrastructure,please find the below existing Tele presence setup ,please suggest the product list is required for the jabber video integration.
Cisco VCS
Cisco VCSE
Cisco MCU 4220
Thanks in Advance
03-27-2015 10:52 PM
You will need TMS with provisioning licences, TMSPE and you will also need the provisioning option key installed on your VCS-C.
See the prerequisites in the JabberVideo admin guide; http://www.cisco.com/c/en/us/td/docs/telepresence/endpoint/Jabber_Video/4_8/CJAB_BK_J4DBC2E7_00_jabber-video-admin-guide-4-8.pdf
TMSPE Deployment Guide: http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/tmspe/install_guide/Cisco-TMSPE-with-VCS-Deployment-Guide-1-4.pdf
TMS Admin Guide: http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/tms/admin_guide/Cisco-TMS-Admin-Guide-14-6.pdf
/jens
Please rate replies and mark question(s) as "answered" if applicable.
03-27-2015 11:20 PM
Thanks for you replay,
please find the below boq of the TMS ,can you please check apart from list any other license required for the TMS.also please find the attached vcs license key webpage screenshot there is key for the provisioning .
CTI-TMS-SW-K9 | Cisco TelePresence Management Suite - Includes 10 Systems |
LIC-TMS-25 | Cisco TMS - Additional 25 Direct Managed Systems |
LIC-JAB-MOB-25 | TMSPE - Add 25 Active Jabber Mobile Client Registrations |
LIC-MOVI-25 | TMSPE - Add 25 Active Jabber Video Client Registrations |
LIC-TMS-APL-S80100 | TMS Appliance Lic Key Base Software Image Used During DF |
LIC-TMS-10-INCL | Cisco TMS - included 10 System License |
LIC-TMS-SW-PAK | TMS PAK for Configuration Use |
SW-TMS-14.X-K9 | TMS Base Software Image Version 14.X |
Please confirm the same.
Thanks in advnce
03-28-2015 12:38 AM
Just be aware that JabberVideo (was Movi) and Jabber Mobile are different products and you will need CUCM as well if you want Jabber Mobile (the UC client).
Otherwise ok, however, you might want to reach out to your Cisco rep for advice as to what would be the best deployment scenario based on your requirements as JabberVideo is EOL/EOS - (can still be used though) - and has merged with Jabber which now uses the Movi Prescision Video Engine (PVE).
/jens
03-29-2015 12:25 PM
Just to add emphasis on Jens' point: Jabber Video/Movi is EoL: http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/jabber-video-telepresence-movi/eos-eol-notice-c51-732787.html
You should not be spending money on the legacy Tandberg solution at this point. You need Cisco UC Manager as a call agent for Jabber, possibly Conductor to front-end the MCU (required for new TelePresence Severs SKUs) and then can reuse VCS to configure Jabber MRA and B2B calling. TMS is great for scheduling conference resources but not required for normal Jabber functionality.
