LDAP integration with TMS via SSL
Omar Gamil
Hi all, I have LDAP using SSL for communication. What is the needed configuration (port number, Certificate upload) from Cisco TMS side to integrate with that LDAPs. If we need to upload a certificate to the TMS server, how can it done?
Patrick Sparkman
Certificate for outbound connections from TMS can be applied using TMS Tools located under Start > Programs > Cisco TelePresence Management Suite, the steps are covered in the Security Settings section under the Cisco TMS Tools chapter of the TMS Admin Guide.  An example is also provided by Cisco: TMS Certificates with TMS Tools for TLS Communication Configuration Example.
Certificates for inbound connections to the TMS website and API can be uploaded during the installation of TMS or afterward in IIS.  Simply upload the certificate at the top-level within IIS and then edit the website bindings so that HTTPS will use the newly uploaded certificate.
Omar did you get this working yet?
Would like to hear if this worked for you.  In CUCM you would just upload the ldaps server ssl cert as a tomcat-trust restart tomcat, use port 636 or 3269, and ensure to call out the LDAP server buy hostname in the CN: name of the cert.
I don't see documentation that calls out if SSL LDAP is an outbound connection? In CUCM we don't think about this.
Paul can you clarify?
