LLQ on atm ima
d.rocco
I'm trying to apply the "service-policy output" command under PVC of an ATM IMA subinterface.
When i configure it, i'haven't errors but in show running-config i don't find the command.
The router is a 3640 with 12.2(2)T IOS Ip plus.
I found that initially was only supported for 7200/7500 series router (see link below).
http://www.cisco.com/en/US/partner/tech/tk39/tk824/technologies_tech_note09186a0080094706.shtml
Do you know if is this a bug?
Is there an IOS that support this features for 3640?
tsettle
Level 3
Level 3
This could very well be a bug. Sometimes there are cosmetic issues, for example if there is a policy action configured that isn't supported on the interface type. There are many bug fixes for QoS/CEF/ATM/IMA since the release you are running. I know of few successful implementations using IMA on 3640 that have run 12.2.13T. You may want to try latest 12.2T code.
tsettle
Level 3
Level 3
patrick.hurley
Level 3
Level 3
You have to have traffic shaping enabled or it won't work. The vbr-nrt command under the pvc.
pvc 0/100
vbr-nrt x y
service-policy output ATM_POLICY
