Local Phonebook
yuvalkvity
I have a few contacts on my local phonebook that i want to show them on the main screen/home page as favorites folder.
Is it possible or maybe there is a better way?
Best regards.
Paulo Souza
I don't think it is possible, but if you use remote control, you can access the phonebook by pressing one single button, the "phonebook" button (it is a book icon). If you use touch device, you can set phonebook page as the first page on the touch screen.
I hope this help.
Paulo Souza
Please rate replies and mark question as "answered" if applicable.
Paulo Souza Was my response helpful? Please rate useful replies and remember to mark any solved questions as "answered".
If you have a c series codec, you can assign phone book entries to the soft buttons on the remote, so you can have up to 5 contacts assigned. This can be completed through the config  menu, but I can't remember where off the top of my head. I think you maybe able to do something similar with the MXP series as I remember re-mapping keys at some point in the past.
Chris
yuvalkvity
Thanks for replay.
Yes, i already knew about both ways, but i wanted to know if possible to make another bar in the menu (like in other
suppliers).
I assunged speed dails in the top remote buttons.
Thanks again
