ā06-30-2013 03:19 AM - edited ā03-18-2019 01:23 AM
I have a few contacts on my local phonebook that i want to show them on the main screen/home page as favorites folder.
Is it possible or maybe there is a better way?
Best regards.
ā07-01-2013 04:55 AM
I don't think it is possible, but if you use remote control, you can access the phonebook by pressing one single button, the "phonebook" button (it is a book icon). If you use touch device, you can set phonebook page as the first page on the touch screen.
I hope this help.
Paulo Souza
Please rate replies and mark question as "answered" if applicable.
ā07-01-2013 04:04 PM
If you have a c series codec, you can assign phone book entries to the soft buttons on the remote, so you can have up to 5 contacts assigned. This can be completed through the config menu, but I can't remember where off the top of my head. I think you maybe able to do something similar with the MXP series as I remember re-mapping keys at some point in the past.
Chris
ā07-01-2013 10:20 PM
Thanks for replay.
Yes, i already knew about both ways, but i wanted to know if possible to make another bar in the menu (like in other
suppliers).
I assunged speed dails in the top remote buttons.
Thanks again
