08-06-2013 12:34 AM - edited 03-18-2019 01:34 AM
Hello cisco world Ii'm new and i hope that with your help i will soon be able to work with the VCS and the MCU
The problem is
I cannot register the h323 to the VCS
h323 gatekeeper : Enabled
h323 gatekeeper address : the address of the vcs
gatekeeper reg type : mcu standard
mandatory h323 id to register : mcuatprobadotbg
password :empty
and the other fields are empty
in the SIP page everything is OK and it is with status Registered but on the h323 page the results are :
h323 gatekeeper status name resolved to the ip of the vcs
Registered address not registered
Alternate gatekeeper available 0
Thanks !
Solved! Go to Solution.
08-06-2013 03:34 AM
Hello Svetoslav
What do you see in VCS log ?
Status>Logs>Event log
br Oleksandr
08-06-2013 07:33 AM
08-06-2013 03:34 AM
Hello Svetoslav
br Oleksandr
08-06-2013 07:26 AM
Zdrastvuvai Hello my friend
this is what i get
2013-08-06T17:24:13+03:00 | tvcs: Event="Registration Rejected" Reason="Time difference too large for authentication" Service="H323" Src-ip="192.168.1.221" Src-port="2222" Dst-alias-type="H323" Dst-alias="mcu@proba.bg" Protocol="UDP" Level="1" UTCTime="2013-08-06 14:24:13,194" |
08-06-2013 07:33 AM
Ok.
First, you need setup properly NTP on VCS and MCU
br Oleksandr
08-06-2013 10:20 AM
Thanks mate tomorrow i will try and write what happened.
08-07-2013 12:09 AM
Thanks a lot problem solved! I reconfigured the NTP server and some other stuff and it worked thanks again!
