02-21-2015 12:06 PM - edited 03-18-2019 04:03 AM
Good day! Could you explain me how can I record sharing presentation between two EX90 enpoints if two endpoint register on CUCM? Does MediaSense incude a possibility to record content?
03-07-2015 01:10 AM
I have been browsing all the documents related to MediaSense and there's not any mention to "content sharing" or "BFCP support" or something related to.
Also from Cisco Jabber when I call MediaSense, I can see the "Screen Share" button greyed out while I have enabled BFCP support everywhere in the devices and the trunks. The Screen Share is functional when it's a question of a Jabber to Jabber call.
I can here understand that MediaSense doesn't support BFCP.
03-08-2015 04:30 PM
I did not work with mediasense and the documentation which I saw did not contain
any info regards bfcp, presentation or dual channel or something like that
(sadly neither regards the support nor the lack of support).
Is this something you need on a big scale or smaller? An old style of deployment which
would work is either to use the local multisite of the endpoint to dial into the Cisco TelePresence Content Server (TCS)
or use a preconfigured / auto dialed participant on a specific MCU or TPS, also using the TCS
