Merge directories between 2 seystems
Shy Solenko
I'v got 3 endpoints (2 sx20 and 1 edge 95).. the client want to merge the directories of all systems.
There is any way to do it/?
they don't have cucm or TMS its just endpoints..
Thankd
Jens Didriksen
Level 9
Level 9
Unfortunately no - they'll have to manually enter all the addresses into each end-point.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
Got it thanks
The only way to do it is with TMS?
Yes, problem is the MXP and the C-series (SX included) use different file formats, so without TMS it's just not going to work.
/jens
Martin Koch
There is no direct file which you can exchange or synchronize, but you have
api commands to read out the phonebook, which are more or less just text entries,
so its not that hard to post process that.
If its a one time thing it should be quite simple with some manual work.
If you expect to keep it synced, you would need some sync logic with some
checkup (like duplicates).
There are some 3rd party also offering phonebooks as a service,
so you do not need to have a TMS but they can manage them (either with
their TMS or some custom phonebook server.
Please remember to rate helpful responses and identify helpful or correct answers.
