04-08-2019 03:08 PM
Might someone able to help me or put me into the right direction? I am trying to connect my WDA to a Cisco SX80 device through its HDMI port unsuccessful. The WDA device works perfectly on the TV/monitor. There is sufficient USB power too. The Cisco SX80 device HDMI port is working well as well if I connect my laptop through HDMI cable. WDA has been firmware upgraded.
Actually I am looking for a solution similar to proximity but with proper video and sound transferring ability.
Your kind advise appreciated.
Bests,
Gabor
Solved! Go to Solution.
04-09-2019 08:47 PM
As @PJMack said, the Microsoft WDA is an HDCP device, so the SX80 will (correctly) disable that input when it detects HDCP content.
You will either need to use a different endpoint that will support local display of HDCP content (Codec Plus, Codec Pro, Room 55 Dual, Room 70, Room 70 G2), or insert another hardware component between your WDA and the SX80 to strip the HDCP. The latter option will allow the content being shown to also be sent over a connected video session.
Please remember to mark helpful responses and to set your question as answered if appropriate.
04-09-2019 10:47 AM
If I'm not mistaken, the Microsoft WDA has HDCP enabled. If so, it won't work, DX80's don't support HDCP input. Some video room systems now do, but not desktop systems.
See if you can find a way to turn it off, otherwise you'll need a different solution.
04-09-2019 01:34 PM
04-09-2019 08:47 PM
04-10-2019 05:36 AM
Dear Wayne and all,
thank you for your time and effort answering me, now I know how to carry on.
Bests,
Gabor
04-11-2019 06:56 AM
Dear Wayne,
is there any (Cisco) product/equipment that could be used transferring data (video+sound) wireless from a laptop into SX or MX codec?
Gabor
04-14-2019 11:17 PM
That will depend on how your endpoint is registered and what other infrastucture you may have present.
A couple of options are Cisco Proximity (if you register on-prem - but this has some limitations on frame rates), or Cisco Webex Teams (if you are cloud registered - although, recent versions of the Webex Teams client may also work on-prem endpoints).
04-15-2019 02:30 AM
Thank you! I think I wait for proximity to improve... :)
04-15-2019 03:15 AM
Given the way that Proximity works, I don’t have a lot of faith that it will improve much at all. There is significantly more development effort going in to WxT, and it’s a significantly more capable product. I’d recommend that as a better product.
04-15-2019 08:18 AM
04-15-2019 04:55 PM
The Webex Share allows people using Webex Teams to share to a screen that doesn't have a TelePresence endpoint connected. I guess you could use it as a sharing device plugged in to an HDMI input on a codec if your device isn't registered to the cloud already, but for a device connected to the Webex Cloud, this would just be a double up of capability.
04-16-2019 05:39 AM
