Migrating from TMS Agent Legacy
csco10580709
I should do a migration from TMS legacy mode to TMSPE mode, we use a separate SQL server for the tmsng database and we will use the same SQL location for the tmspe data base.
Is it necessary to create an emty tmspe database on the SQL server before the migration?
And how much space should I reserve on the SQL server for about 500 users?
Thanks!
Henrik Jensen
Paulo Souza
Hi Henrik,
Yes, you must to create a empty database on SQL for TMSPE before migrating. During the migration, the setup will automatically migrated the legacy OpenDS database do SQL. You will be prompt to insert the information to connect to SQL Server during the instalation of TSMPE.
With regards data abse size, I have a TMSPE base with 100 users registered, the size, including data and logs, is just 15 MB. =)
See:
Paulo Souza
Paulo Souza Was my response helpful? Please rate useful replies and remember to mark any solved questions as "answered".
Paulo Souza
Hi Henrik,
See:
Paulo Souza
You must to create the base for TMSPE according to especification described on this guide:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/tmspe/install_guide/Cisco_TMSPE_Deployment_Guide_1-0.pdf
Hi Paulo
Thanks a lot, I will go on
Henrik
