Miracast not working on RoomOS 11.24.3.0
Latest on prem software upgrade breaks Miracast.
RoomOS 11.24.3.0
Far end only gets a green image.
Software swap / Downgrade to RoomOS 11.20.3.0 solves the issue.
Confirmed with sevral room bars, room kits and source PCs to various connected endpoints.
9 Replies 9
Jonathan Schulenberg
Appreciate the heads up. Please share the defect ID from your TAC case when they provide it.
I would recommend opening a case with TAC and filing a de facto report, if the Miracast is breaking on the latest version.
Response Signature
Yeah, I tried to file a bug report with TAC, they were less than helpfull and told me to contact my supplier instead.
Push back if you have regular SMARTnet contract on that serial number. The only valid reason for them to brush you off would be the absence of a support contract or if your partner sold a variation of the regular offer where they are required to take first call to triage and then escalate to Cisco if needed.
Escalation path:
  1. The manager of that engineer.
  2. Your Cisco account team and potentially Cisco reseller.
  3. The Duty Manager - ask for them when calling TAC front line.
If I look in Control Hub our stable version is 11.26 and it was released in the beginning of March. Based on this the 11.24 version should have been released in January 2025.
Response Signature
Thank you, but as stated earlier this is for on-prem, released 07-Mar-2025
What I shared is also for on-prem, updated from cloud.
Response Signature
Yes but that requires Webex Edge for Devices which, while ideal, may not be possible for the OP (e.g., air gapped environments or another ecosystem such as Zoom Node Conference Room Connector).
AFAIK the OP has two choices: push back on TAC or wait and hope it works again in the next release published to Cisco.com. Personally, I’d choose the former.
I tried to push back against TAC and CCed the manager this time.
Engineer just copy pasted her earlier responce once again.
I contacted our supplier/reseller as well just now asking why for the first time since 2008 TAC has an issue with me contacting them.
