Multipoint license for Spark kit plus
Johnny0194
How to configure the multipoint license in the BOM for spark kit plus
PJMack
Level 7
Level 7
You are asking how to order multisite, correct? For some reason it's a separate order on these newer systems from Cisco rather than an option like it used to be. Check the ordering information in the datasheet, it's in there:
 https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/spark-room-kit-series/datasheet-c78-738752.html
You need to use the L-ROOM-PAK as the top level part number and then L-KIT-MS
Rishabh Gupta
HI Johnny,
In case , If it is about installation of the Multi-Site key, you can refer below steps:
  1. Sign in to the web interface and navigate to Maintenance >Option Keys.
  2. You see a list of all option keys, also the ones that are not installed on your video system.
  3. There you can enter an Option Key in the text input field and then click Add option key.It would need a restart to take effect.
