MX300 proxy setting form touch panel
Syed
Level 3
Level 3
Dear All,
Can I change proxy setting of MX300 from its touch panel or it is only through GUI admin interface?
Syed
6 Replies 6
Patrick Sparkman
I assume you're referring to SIP proxy.  If so, you can use either the Provisioning Wizard on the Touch 10, or manually via the web interface.
  • Touch 10: Settings > Administrator > Provisioning
  • Web interface: Setup > Configuration > SIP
This is based on CE8.2 software, if running TC software some menus might be named differently.
Thank you Patrick.
I hope all Touch panel settings will remain same, correct me, please?
They wizard will pre-populate with the settings from the endpoint, only the settings you alter will be changed, the rest will remain the same. Any other Touch 10 settings that can be changed by the user outside of the wizard, such as volume for example will remain the same.
I mean, can it be changed from any touch panel? or only on the latest ones?
Is the MX300 a G1 or G2?
What I've outlined above with the Touch 10 is for a G2, while the G1 will use the Touch 8, but the process should be the same regardless of the endpoint and touch panel.
perfect.
I shall follow the steps and come back to you soon.
Thank you Patrick.
