MX300 with no TP licence
ArSh21
Is it possible to register an MX300 to CUCM without a TP license, as a demo for a specific time?
Also, does it require a VCS/Express ?
Thank you.
6 Replies 6
R0g22
You need a TP license. Demo license request needs to go to your Accounts Manager/SE.
You can run CUCM as "out of compliance" for up to 60 days when you don't have enough licenses, it will just show a warning when you login (this applies to all license types, not just TP room licenses).
Expressway is required if you want to conference with other organisations over the internet but is not required for conferences within your own LAN/WAN.
Does that it'll work but with limited functions ?
Dennis Mink
it only needs a VCS if you want to use it in conjunction with being able to make external "URI calls".
have you got a standalone unit. in which case you might want to consider registering it with webex cloud instead
Please remember to rate useful posts, by clicking on the stars below.
How can I register it with Webex ?
You will need a Webex account, and from the Webex Control Hub, you should be able to generate an activation code for your endpoint to register to your Webex org.  Enter this code on to endpoint in the setup wizard, and it will work with your Webex  There are some good instructions on how to do that in the Collaboration Help site here: How Do I Add an Endpoint in the Cisco Webex Control Hub?
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
