MX800 No audio on HDMI output 2
david.sharp
I have a simple problem which isn't making much sense, we need to take a video and audio output from an MX800 so that we can record a conference and this is providing to be a more difficult task than expected.
The firmware is TC7.3.4 and we are finding that no matter what we do we are unable to get audio out of HDMI 2 which according to the manual should be supported, we can get audio out of HDMI 1.
The config appears to be correct
*c xConfiguration Audio Output HDMI 2 Level: 0
*c xConfiguration Audio Output HDMI 2 Mode: On
I understand that one of the audio DSP's or maybe multiple will be used for the inbuilt audio on the system, but as the manual states only 1 is used to the other should be available.
Should we expect audio on the HDMI output 2?
Cheers
Dave
Think with Portals
15 Replies 15
Hi Folks,
We have Deployed around 50 MX 700/800 dual screen device's  isrunning on CE8.3.1 and CE 8.2.2 firmware. while someone from Farend side share the content/audio play from farend locally/Near end audio is coming/hearing from only 3 Left side speaker Few of device's audio is coming from both side  left and right 3 No speaker. Connectivity is same for all the speaker's. We have compare both working and non-working system and replicate same setting. but maximum MX 700/800  audio not working speaker left side speaker. Please Check if any settings need to be done or we need to be enable audio out for HDMI 2 2nd display. We are missing anything. Please suggest your feedback is really appericated !
Robin Chibber
