MXP Upgrade to F 9.0.2 from F 5.0
stanley.april
I want to upgrade all of my MXP systems to the latest F 9.0.2 . Some of my MXP systems are at F 5.0, F 6.0 and F 7.0.
Do I need to upgrade step by step for these systems , that is upgrade to F 6.0 , then upgrade to  F 7.0, then upgrade to F 8.0 and then upgrade to F 9.0.2?
dougscr1b
You do not have to step up one version at a time.  You can go right to the latest.  The only exception is if you are below version 3.0; you must upgrade to at least 3.0 before going on.
dougscr1b
Thanks for your help!
