New TMS Server Migration Template Problems
rasimyigit
Hi All,
i have a problem with implementing Templates. They gave me always the Message in new TMS:
"An Xml error occurred. Details: Data at the root level is invalid. Line 1, position 1".
I cant implent some Templates on the endpoints. The Endpoint is mixed like C series and MXP's
Since to work with the new TMS Server , we've got this problem.
The Old TMS was a Appliance (TMS 13.1.2) and the new TMS is VM Win2008 Server(TMS 13.1.2).
any one has an idea?
THX
Magnus Ohm
Resolved
The problem was the custom command having an incorrect entry for setting the menupassword. By removing the costum command it was working fine.
We changed the entry from SystemUnit MenuPassword Set Password: xxxxx to
1234
And it was now working fine.
7 Replies 7
Magnus Ohm
Hi Rasim
I got the TAC case you opened. I suggest we troubleshoot the issue over webex and when we solve it we can share the resolution here.
/Magnus
Hi Magnus,
tomorrow?
THX
Best Regards
Mit freundlichen Grüßen
Rasim Yigit
System Engineer
Professional Service
Dimension Data Germany AG & Co.KG
In den Schwarzwiesen 8
61440 Oberursel
Büro: +49 (6171)977244
Fax: +49 (6171)977150
Mobile: +49 (174) 3299142
rasim.yigit@dimensiondata.com
For further information about Dimension Data, please go to www.dimensiondata.com/de<>
Magnus Ohm
Yes.
I will send you tomorrow a time, because im not sure now , when I’m tomorrow available
THX
Best Regards
Rasim Yigit
System Engineer
61440 Oberursel
Hi Magnus, are you have Time now ?
Danke
Gruß Rasim
iPhone4s gesendet
Am 10.04.2012 um 17:17 schrieb "mohm" >:
Home<>
Re: New TMS Server Migration Template Problems
created by Magnus Ohm<> in TelePresence - View the full discussion<>
Magnus Ohm
Resolved
1234
it works.
Thank you very much
Bye
