NO HTTP RESPONSE
Chet Cronin
Level 4
Level 4
Have an issue with some of my systems on TMS that I am receiving more No HTTP Response warnings.
I verified HTTPS is running properly on TMS and I have the SNMP and HTTP off, and HTTPS set on for the endpoints.  No firewall involved as systems are all inside our firewall.  Other systems are connected with no issues.   All are on either firmware f9.3.4 or TC7.3.7.
Any Ideas would be appreciated.
VR
Chet
Chet Cronin
Elias Sevilla Duarte
Are those systems reachable from TMS? You can confirm that by doing a connection attempt as below:
From TMS, go to Navigator --> Endpoints --> click on one of the endpoints with the "No HTTP response" flag, and within the endpoint`s information go to the "Connection" tab, and click test connection.
This will show an output with the results. If the systems are reachable via HTTP or HTTPS the warning message will desapear, however if there is no response from the system you may want to verify if the systesms are turned off, or if the External Manager settings for provisioning are set to off in the endpoints.
I hope this helps.
Patrick Sparkman
