04-23-2024 10:41 PM
Does anyone have the cisco powerpoint describing setting up the passthru options for the webex room kit plus, kit pro ? I believe one option was using the vaddio a/v bridge. Looking for cisco's recommendations for setting up passthru ..
Solved! Go to Solution.
04-25-2024 12:14 AM
Sir,
Sorry for the delay ... your input helped very much ... Thank you.
04-24-2024 02:44 AM
It’s in the zip file for the USB Macro; however, you can use Call from Laptop in RoomOS 11 to avoid the actual macro.
04-25-2024 12:14 AM
Sir,
