Power Injector for Touch 10
rpacker
Level 4
Level 4
We are trying to get a Touch 10 power injector for a customer who recently bought a room kit and the injectors are on a long back order- part number CS-POE-INJ=. Are there any alternative injectors that they can use?
CTS-PWR-AIR-INJ5 will reach EOS June 7, 2021 so you have just one month to place the order. So better to go with CS-POE-INJ=. Any Power Injector 802.3af or 802.3at can power the Touch 10. since all document prefer  802.3af go for it.
Response Signature
Asper the data sheet recommended  will be below mentioned.
Cisco Touch 10 PoE power injector
CS-POE-INJ=
POE16U-1AF, FA015LS1-00
What you mean by alternative?
Response Signature
Response Signature
Vaijanath Sonvane
As per installation guide you can use Cisco Aironet Power Injector (CTS-PWR-AIR-INJ5).
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/touch/installation_guide/touch-10-installation-guide-en-fr-es-pt-it-de.pdf
Any POE Switch or Midspan Power Injector should work for Cisco Touch 10.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
rpacker
Level 4
Level 4
Thanks!
