09-27-2016 12:15 PM - edited 03-18-2019 06:25 AM
I been going through some web links and thought I would come here see if I can get some additional help
I have PrecisionHD 1080p camera which connected to C40
in CUCM 10.5 environment
Currently not using expressway
Not using SIP URI
Is there a way to use the PrecisionHD 1080p camera as a stand alone camera connected to a PC?
Is there a way to use the PrecisionHD 1080p camera and C40 to participate in webex meeting ?
Solved! Go to Solution.
09-27-2016 01:21 PM
If the person hosting the WebEx meeting is using WebEx Meeting Center and has CMR Cloud, than yes you can participate using the C40, you'd simply make a SIP call from the C40 into the WebEx meeting.
It's not possible to simply use the PrecisionHD camera or any camera meant for a TelePresence endpoint to be used a PC camera. However, there are some workaround where you could get video from the camera, but you'd have to purchase and use third-party devices. This has been discussed a few times, here is on such thread in the forums: using-codec-camera-webcam.
09-27-2016 01:21 PM
09-28-2016 10:16 AM
Patrick what about the MX200 or with your statement does it apply to all video endpoints?
09-28-2016 10:37 AM
Applies to all video endpoints.
